Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Note
This product is currently discontinued. To view and buy our latest industrial-grade Soil-Moisture & Temperature Sensor, kindly follow the link here.
Moisture and temperature of soil are two main concerns in agricultural area. This sensor is prepared for applications that require precise monitoring over moisture and temperature conditions. The SHT-10 sensor inside brings satisfying high resolution. The typical temperature resolution is 0.4°C, while typical moisture resolution is 3%RH. With a copper sintered mesh over the sensor, you have no worry about its anticorrosion performance.
  • High resolution
  • Durable, stable and reliable
  • Industrial level gadget
  • Serial two-wire interface
  • Individually calibrated
Specifications
  • Temperature measuring range: -40 ~ +123.8°C
  • Moisture measuring range: 0 ~ 100% RH
  • Temperature accuracy: ±0.4°C
  • Moisture accuracy: ±3%RH
  • Cable in length: 1m
  • Wires: Red = VCC (3-5VDC), Black or Green = Ground, Yellow = Clock, Blue = Data.
Dimensions
Certification
HSCODE9025800000
USHSCODE9025801000
UPC841454116240
EUHSCODE9013101000
COOCHINA
Technical Details
Dimensions80mm x120mm x15mm
WeightG.W 72.5g
BatteryExclude
Soil Moisture & Temperature Sensor
SKU 314010012
USD$39.90
Discontinued
You may also add
