Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
NOTE:
Please be aware that due to the production testing process, there may be some white glue residue visible near the RFIO interface of the Wio-WM1302 (SPI) - AS923 LoRaWAN Gateway Module, as shown in the image below.
This residue does not affect the product's performance or functionality in any way.
We recommend that customers with specific expectations about the product’s appearance keep this in mind when ordering.
  • Powered by Semtech® SX1302 baseband LoRa® chip, extremely low power consumption and high performance.
  • Mini-PCIe form factor with the standard 52-pin golden finger, easy to integrate with various gateway devices.
  • Ultra-low operating temperature, no additional heat dissipation needed, reducing the size of LoRaWAN gateway.
  • High sensitivity down to -139 dBm @SF12 with SX1250 TX/RX front-end; TX power up to 26 dBm @3.3V.
  • Certified with CE(EU868), FCC ID(US915), and TELEC(AS923).Simplify the final product certification process.
Wio-WM1302 module is a new generation of LoRaWAN gateway module with a mini-PCIe form factor. Based on the Semtech® SX1302 baseband LoRaWAN® chip, Wio-WM1302 unlocks the greater potential capacity of long-range wireless transmission for gateway products. It features higher sensitivity, less power consumption, and lower operating temperature compared with the previous SX1301 and SX1308 LoRa® chips.
The WM1302 module has passed various certifications such as CE (EU868), FCC ID (US915), TELEC (AS923). These help to simplify the development and certification process of long range gateway devices.
Wio-WM1302 is designed for M2M and IoT applications and can be widely applied in LPWAN gateway-supported scenarios. It would be a perfect choice for you to significantly reduce the technical difficulties and time consumption when developing the LoRa gateway devices, including the LoRaWAN gateway, etc.
Region
WM1302 (EU868)
WM1302 (US915)
WM1302 (AS923)
Frequency
863-870MHz
902-928MHz
920-923MHz
Sensitivity
-125dBm @125K/SF7
-139dBm @125K/SF12
-125dBm @125K/SF7
-139dBm @125K/SF12
-125dBm @125K/SF7
-139dBm @125K/SF12
TX Power
26 dBm (with 3.3V power supply)
25 dBm (with 3.3V power supply)
LEDs
Power: Green Config: Red TX: Green RX: Blue
Form Factor
Mini PCIe, 52pin Golden Finger
Power Consumption (SPI version)
Standby: 7.5 mA
TX maximum power: 415 mA
RX: 40 mA
Power Consumption (USB version)
Standby: 20 mA
TX maximum power: 425 mA
RX: 53 mA
LBT(Listen Before Talk)
Supported
Antenna Connector
U.FL
Operating Temperature
-40°C to 85°C
Dimensions
30 mm (width) × 50.95 mm (length)
Certification
Hardware Overview
Diagram
Pinout
Application
  • LPWAN Gateway devices development
  • Any long-distance wireless communication application development
  • LoRa and LoRaWAN application learn and research
Certification
HSCODE8517799000
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
Wio-WM1302 LoRaWAN Gateway Module
*1pcs
Wio-WM1302 LoRaWAN Gateway Module (SPI) - AS923
SKU 100021717
The Wio-WM1302 module is a new generation of LoRaWAN gateway module in mini-PCIe form-factor based on Semtech® SX1302. It features extremely low power consumption and outstanding performance.
Version
Region
SX1262
USD$35.90
You may also add
