seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      XY-Plotter Robot Kit v2.0 (No electronic)
      SKU 114990138
      $209.99
      DISCONTINUED
      Introduction:
      Makeblock XY-Plotter 2.0 is a updated version of XY-plotter. With the Processing and GRemote, You can draw amazing pictures with Gcode.
      Since we reinforce the structure, the XY-plotter 2.0 is stronger enough to be conversed to MiniCNC, 3D printer, driller, etc. And the movement of the terminal is stable and precise since the improved dual-way transmission mechanism.
      Features:
      • Strong aluminum extrusion parts, anodizing surface
      • Two Metal stepper motor with back shaft
      • 12V Solenoid include
      • Closed type bushing block and ball bushing insert for use in linear motion applications
      • Four-bolt aluminum alloy bushing block for a lightweight ready-to-mount installation
      • Synthetic resin retainer plate for accurate ball guidance and low noise
      • Four rows of recirculating balls inside the ball bushing for smooth running
      • Integral lip seals to retain lubricant and protect against contamination
      • Round steel shaft for use with slide units in linear motion applications.
      • Chrome plated for corrosion resistance
      • Case hardened for wear resistance
      • Precision ground for consistent ball bushing radial clearance
      Note:
      With this kit, you can only build a XY-Plotter without controller. You can use your own electronic parts to drive this.
      Part List:
      4 × Linear Motion Shaft D8×480
      2 x Stepper Motor
      30 × Plastic Rivet 4120
      6 × Linear Motion Slide Unit 8mm
      2 × Stepper Motor Bracket
      25 × Plastic Ring 4x7x2mm
      1 × Solenoid-12V
      4 × Timing Pulley 90T
      10 × Plastic Ring 4x8x1mm
      2 × Beam 0824-496
      8 × Timing Pulley Slice 90T
      35 × Screw M4×8
      1 × Beam 0824-144
      1 × Open-end Timing Belt (3m)
      60 × Screw M4×14
      3 × Beam 0824-128
      3 × Link Rod
      2 × Srew M4×30
      1 × Beam 0824-96
      2 × Shaft Connector-4
      40 × Nylong Lock Nut M4
      3 × Beam 0824-80
      3 × Threaded Shaft 4×39mm
      20 × Nut M4
      1 × Beam 0808-96
      3 × Shaft Collar 4mm
      15 × Nylon Cable Ties
      1 × General Bracket
      4 × Flange Bearing 4x8x3mm
      1 × Cross Screwdriver
      2 × Bracket 3x6
      8 × Headless Set Screw M3x5
      1 × Screwdriver 3mm
      14 × Bracket 3×3
      15 × Countersunk Screw M3x8
      2 × Screwdriver 1.5mm
      2 × Plate 3×6
      Documents:
      How to use
      The user guide and troubleshooting of XY-Plotter
      XY-Plotter Using Gcode Interpreter
      Github
      Technical Details
      WeightG.W 3100g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 114990138
        $209.99
        DISCONTINUED
        $209.99/1pcs+
        $188.99/10pcs+
        $178.49/20pcs+
        $167.99/50pcs+
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
