Grove - MP3 v2.0
We've released the upgrade version Grove - MP3 V3,
the same price, much more function support.
- 10+: $9.80
Grove - MP3 v2.0 is a tiny-size and compact audio module. It supports operations including shuffle and play in an order of various audio files such as WAV and WMV ones. With serial communication, you can use all predefined commands or even the combinations of them to play the music. This module also supports general file systems like FAT16 and FAT32. It gets a Grove UART interface, a 3.5mm audio jack and a micro-SD slot. With this module, you can get some “voices” for silent applications.
Tip
We've released the upgrade version Grove - MP3 V3, the same price, much more function support.
General operations on audio files
On-board micro-SD slot and 3.5mm audio jack
Support sample rate of 8/11.025/12/16/22.05/24/32/44.1/48(KHz)
24-bit DAC output, 90 dB(at Max.) dynamic output range, signal-noise ratio at 85 dB
MP3, WMW and WAV audio formats and FAT16, FAT32 files system supported
Embed 10 levels of equalization in total
Specifications
Input: 5V(DC)
Operating current (without signal output state): less than 15 mA
Operating current (with signal output state): less than 40 mA
Chip: KT403A
Chip LDO output voltage: 3.3 V
Chip output current: 100 mA(at Max.)
File formats supported: MP3, WAV, WMA
Maximum memory supported for SD card: 32 GB
Sampled rate : 8/11.025/12/16/22.05/24/32/44.1/48 (KHz)
Dimensions | 55mm x55mm x10mm |
Weight | G.W 10g |
Grove - MP3 v2.0 | 1 |
HSCODE | 8518900090 |
USHSCODE | 8517180050 |
UPC | 841454118169 |
EUHSCODE | 8517180000 |
COO | CHINA |
RoHS | 1 |
Documentations
from order viewWorks ok
Good MP3 Player!Small size, Simple protocol, used SD Card etc.....
tried.. but not checked yet
