the AI Hardware Partner
Toggle Nav
Loading...
Bus Pirate v4 Acrylic case kit v1
A clear laser-cut acrylic case kit for the Bus Pirate v4
$3.00
Out of stock
A clear laser-cut acrylic case kit for the Bus Pirate v4. This case is designed to be simple, cheap, and easy to assemble. The Bus Pirate PCB is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
WARNING: This fits the earlier Bus Pirate v4 models which comes in the non-Sick of Beige PCBs.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions 68mm x42mm x10mm
Weight G.W 27g
Battery Exclude
HSCODE 3926909090
USHSCODE 3926100000
UPC 841454111153
EUHSCODE 3926909705
COO CHINA
RoHS 1
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    nice case for bus pirate
    By
  2. Product Quality
    80%
    Not bad, no documentation
    I would have preferred a layer style case, like the Pimoroni Coupé, but this is adequate. It comes with two different sizes of hex nut, but the difference is quite subtle and there are no online instructions I could find. Also, the screws are very very tight in the BP holes. You have to force them in very hard.
    By
  3. Product Quality
    100%
    By
  4. Product Quality
    100%
    By
  5. Product Quality
    100%
    By
Items 1 to 5 of 12 total
Page
Show per page
