Intel® Edison Kit for Arduino
Rating:
100% of 100
intel edison kit,intel, edison,edison kit,intel edison
$97.95
Out of stock
  • 10+: $95.00
This kit includes an Arduino Breakout, which essentially gives your Edison the ability to interface with Arduino shields or any board with the Arduino footprint.
Dimensions:127mm x 72mm x 12mm
The Intel Edison module is included.
  • Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32-bit Intel® Quark™ microcontroller at 100 MHz. It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp.
  • The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future.
  • It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service.
  • Has an SD card connector, micro USB or standard sized USB host Type-A connector(via mechanical switch), Micro USB device, 6 analog inputs, and 20 ditial input/output pins, 1x UART, 1x I2C, and 1x ICSP 6-pin header (SPI) Power jack with 7V-15V DC input.
  • Intel® Edison Module
  • Intel® Edison with Kit for Arduino
Physica
Form factorBoard with 70-pin connector
Dimensions127.0 x 72.0 x 12.0 mm
Operating temperature0 to 40 degC
ConnectorHirose DF40 Series (1.5mm, 2.0mm, or 3.0mm stack height)
Memory
Max Memory size4GB
Memory typeDDR3, Nand Flash
Physical add. Ext.32-bit
# of DIMMs0
ECC Memory supported:NO
External Interfaces
Total of 40 GPIOs which can be configured as:
SD Card1 Interface
UART2 Controllers
I2C2 Controllers
SPI1 Controller with 2 chip selects
I2S1 Controller
GPIOAdditional 12 (with 4 capable of PWM)
USB 2.01 OTG Controller
Clock Output32 KHz, 19.2 MHz
Major Edison Components
SoC22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz
RAM1 GB LPDDR3 POP memory
Flash Storage4 GB eMMC
WiFiBroadcom 43340 802.11 a/b/g/n
Dual-band (2.4 and 5 GHz)
On board antenna or external antenna SKU configurations
BluetoothBT 4.0
Power
Input3.3V - 4.5V
Output100ma @3.3V and 100ma @ 1.8V
PowerStandby (No radios): 13mW
Standby (BT 4.0): 21.5mW
Standby (WiFi): 35 mW
Firmware + Software
CPU OSYocto Linux v1.6
Development EnvironmentsArduino IDE
Eclipse supporting: C, C++, Python
Intel XDK supporting: Node.JS, HTML5
MCU OSRTOS
Development EnvironmentsMCU SDK and IDE
Documents
Related Products
Dimensions 0mm x0mm x0mm
Weight G.W 152g
Battery Exclude
Intel® Edison Module 1
Intel® Edison with Kit for Arduino 1
HSCODE 8543909000
ROHS 1
Customer Reviews
  1.
    Rating
    100%
    Review by
    Posted on
  2.
    Rating
    100%
    Review by
    Posted on
  3.
    Rating
    100%
    Review by
    Posted on
  4.
    Rating
    100%
    It is easy to use with arduino sensors.
    Review by
    Posted on
  5.
    Rating
    100%
    Review by
    Posted on
  6.
    Rating
    100%
    Review by
    Posted on
  7.
    Rating
    100%
    Thanks :D
    Review by
    Posted on
Product Faqs
Sort by
