Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Built for Physical AI
A 14+2-DOF dual-arm robotic platform designed specifically for Physical AI.
Completely Open
Hardware, software, CAD, SDK, BOM, and algorithms included.
Application Examples
Includes examples for gravity compensation, impedance control, ROS 1, ROS 2, and more.
Joint-Space Trajectories and Cartesian Path Motion
Supports motion commands such as moveJ and moveL.
Dual-Arm Model and Development Resources
Includes a dual-arm URDF model, STL meshes, parameters, and other development resources.
Learn Faster
Comprehensive tutorials from assembly to deployment.
ItemSpecification
Degrees of freedom per arm7+1 DOF
Overall height601 mm
Working radius per arm758 mm
Dual-arm span1,596 mm
Arm body weight~ 33kg
Peak payload per arm10 kg
Rated payload per arm6 kg
Maximum end-effector speed1 m/s
Positioning repeatability±0.5 mm
ServosHTDW-7535-02-CNE × 2, HTDW-6036-02-CNE × 2, HTDW-4438-30-NE × 3, HTDW-5036-02-CNE × 1
Bus communicationCAN FD
Supply voltage48 V
Joint Range of MotionJ1 -95° ~ 175°
J2 -16° ~ 196°
J3 ±90°
J4 -60° ~ 130°
J5 ±78°
J6 ±45°
J7 ±90°
Moveit✅
ROS✅
Python SDK✅
Pinocchio✅
Open Source✅
Hardware Overview
Schematic Diagram of Single-Arm Joint Structure
Engineering Drawing of Single-Arm Structure Dimensions
Application
Embodied AI Research
Supports dual-arm coordinated control, imitation learning, reinforcement learning, and AI policy validation. Enables research activities such as robot teleoperation demonstrations, data collection, and model training, providing a flexible experimental platform for embodied AI algorithm development and the exploration of complex manipulation tasks.
Research and Education
Designed for universities, research institutions, and robotics developers, supporting teaching and experimental research in robot kinematics, trajectory planning, motion control, and dual-arm coordination. Helps developers gain a deeper understanding of robotic control principles while providing a practical platform for robotics innovation and hands-on education.
Industrial Collaborative Assembly
Enables complex tasks such as part grasping, precise positioning, workpiece stabilization, and component assembly through coordinated dual-arm manipulation. Simulates bimanual operations in real-world industrial production, providing a development and validation platform for flexible manufacturing, intelligent assembly, and industrial automation applications.
Certification
HSCODE8479501100
USHSCODE8479500000
UPC
EUHSCODE8479500000
COOCHINA
Robot assemblyx1
Power supplyx1
USB-to-FDCAN adapter boardx1
USB-A to USB-C data cablex1
Termination resistorx2
G-clampx2
reBot Arm T701 HT
SKU 100096484
The reBot Arm T701 HT is a fully open-source dual-arm robotic platform with 14+2 degrees of freedom. It has 14 actuated arm joints and two gripper actuators. Each arm supports a peak payload of 10 kg, and the dual-arm workspace spans up to 1,596 mm. A wide range of application examples helps you get started quickly and experience the fun of robot development.
USD$3999.00
