Built on the reComputer RK3576 Module, the system brings the Rockchip RK3576 computing platform into a compact, deployment-ready industrial computer.
Memory: 4GB / 8GB LPDDR5 (Scalable up to 16GB).
Storage: 32GB / 64GB eMMC(Scalable up to 128GB).
With a built-in 6 TOPS NPU, it delivers efficient AI inference directly on the device, reducing latency and enhancing privacy without relying on the cloud.
AI performance highlights include:
Check the details of the benchmark.
Designed for reliable operation in space-constrained industrial environments, featuring fanless passive cooling and a wide-range industrial power input.
Connect directly to PLCs, sensors, meters and field devices through built-in industrial communication and I/O interfaces, reducing the need for additional interface adapters.
Pre-installed with Armbian and compatible with Ubuntu, Debian, Android and balenaOS, giving you the flexibility to choose the software environment that fits your application.
Adapt the system to different edge deployments with built-in M.2 and mini-PCIe expansion options.
Accelerate AI evaluation and deployment on Rockchip RK3576 with ready-to-use models, environments and deployment workflows. Click to try reComputer AI Lab
Parameter | Description | |
Hardware Specification | ||
Product Series | reComputer Industrail RK3576-0432 | reComputer Industrail RK3576-0864 |
SOC | Rockchip RK3576 | |
CPU | 4x [email protected] + 4x [email protected] | |
GPU | ARM Mali-G52 MC3 | |
NPU | INT8@6TOPS; Supporting INT4/8/16/FP16/BF16/TF32 mixed operations | |
Operating System | ArmBian OS | |
RAM | 4GB | 8GB |
Storage | 32GB | 64GB |
System Specification | ||
Power Input | DC 9V~36V, 2-Pin Terminal Block | |
PoE | 1 x PoE PD | |
Reset | Yes | |
MaskROM | Yes | |
Interface | ||
Ethernet | 1x Gigabit Ethernet | |
1 x Gigabit Ethernet (supports PoE PD) | ||
USB | 2x Type A USB 3.0 | |
1x Type C for OTG & DP | ||
RS485 | 2x RS485 (Isolated) | |
CAN | 1x CAN FD (Isolated) | |
DI | 1 x Isolated DI Ports | |
DO | 1 x Isolated DO Ports | |
Display | 1x Display; 1x DP1.4 via USB Type C port | |
M.2 Slot | 1x M.2 Key M 2280 slot (PCIe 2.1x 1), supporting either an NVMe SSD or an AI accelerator | |
Mini-PCIe | 1x Mini-PCIe for 4G/LoRa/WiFi Halow module | |
SIM Card | 1x Nano SIM Card Slot | |
LED | 1x PWR ; 1x USER ; 1x ACT | |
Buzzer | 1 | |
Button | 1x Reset; 1x MaskROM | |
Audio | 1x 3.5mm Headphone Jack with Microphone Input | |
Wireless Communication | ||
Wi-Fi | Onboard WiFi6 with FPC Antenna | |
BLE | BT 5.4 | |
4G Cellular | 4G LTE* | |
LoRa® | USB LoRa®*/SPI LoRa®* | |
Wi-Fi HaLow | SPI Wi-Fi HaLow* | |
Standards | ||
Certification | CE, FCC | |
TELEC | ||
RoHS | ||
REACH | ||
KC | ||
EUDOC, UKDOC | ||
RCM | ||
Ambient Conditions | ||
Storage Temperature | -20~90 °C | |
Operating Humidity | 10~95% RH | |
Operating Temperature | 0–60°C with 0.7 m/s airflow | |
Mechanical | ||
Dimension (W x H x D) | 131mm x 94.5mm x 56mm | |
Enclosure | Aluminum Alloy | |
Mounting | DIN-Rail Mounting | |
Weight (Net) | 745.7g | |
Others | ||
Heat Dissipation | Fanless | |
Hardware Watchdog | 1~255s | |
RTC | High Accuracy RTC | |
SoC-Integrated Hardware Security | ARM TrustZone, Secure Boot, Secure JTAG | |
Hardware Cryptography | Key Ladder, RSA-4096, AES-256, SHA-512 | |
Warranty | 2 years | |
Production Lifetime | Until January 2036 | |
Statement | Options marked with * require additional purchase according to the accessories list. | |
| reComputer Industrail RK3576 | x1 |
| DIN-rail clip | x1 |
| Screw Pack | x1 |
| 12V/3A Power Adapter (with 1x US/EU/UK/AU Plugs) | x1 |
| DC Power Female Jack to Screw Terminal Adapter | x1 |
| 6*2-pin Terminal Block Connector (Male) | x1 |
| 120Ω Resistor | x5 |
| Wi-Fi/BLE Antenna | x1 |
| User Manual | x1 |
Fanless | Rockchip RK3576 | 6-TOPS NPU | Native industrial I/O | Wide-voltage power input | Hardware watchdog | Automation | Machine vision | Intelligent equipment
