Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • AI Performance: Supports 67 TOPS AI performance in Super Mode with low power and latency, built by NVIDIA Orin SoC combining the NVIDIA Ampere™ GPU architecture with 64-bit operating capability, integrated advanced multi-function video and image processing, and NVIDIA Deep Learning Accelerators.
  • Energy-Efficient Operation: Configurable power modes from 7W to 15W allow for optimized performance and energy consumption. Also 25W in Super Mode.
  • Robust Thermal Design: Operates reliably in temperatures from -10°C to 60°C .
  • Rich interfaces: Features 1xRJ45, 4×USB 3.2, HDMI 2.1, 2xCSI for connectivity and cameras, RTC, CAN, 40-pin and more. Also pre-installed a Wi-Fi/BT combo module, a 256GB SSD.
  • Ready for Deployment: Very suitable for beginners and developers. Supports AI frameworks like NVIDIA Isaac, Hugging Face, and ROS2/1, enabling rapid development of various AI applications.
Jetson Orin Nano / Orin NX Modules Performance with Super Mode
  • Memory Bandwidth Upgrade
  • Higher Throughput
  • Improved higher frame rate processing
  • Enhanced Power Management
  • Reduced Inference Latency
Jetson Orin Nano System on Module
 reComputer J401 Nano Bundle
ModuleJetson Orin Nano 8GB (Super Mode)
AI Performanceup to 67 TOPS
NVIDIA GPU Cores1024 CUDA Cores with 32 Tensor Cores
GPU Max Frequency1020 MHz
CPU6x A78 1.7 GHz
Memory8GB 128-bit LPDDR5 102 GB/s
Video Encoder1080p30 supported by 1-2 CPU cores
Video Decoder1x 4K60 (H.265)
2x 4K30 (H.265)
5x 1080p60 (H.265)
11x 1080p30 (H.265)
Module Power7W | 15W | 25W
JetPackJetPack 6.2 (support JetPack 7.2)
Carrier Board
Storage1x M.2 KEY M PCIe(M.2 NVMe 2280 SSD 256G included)
NetworkingM.2 KEY E1x M.2 Key E (WiFi/BT module included)
Ethernet1x RJ45 Gigabit Ethernet(10/100/1000M)
I/OUSB4x USB 3.2 Type-A (10Gbps)
1x USB2.0 Type-C (Device Mode)
Camera2x Mipi CSI (2-lane 15-Pin)
Display1x HDMI 2.1
Fan1x 4-Pin 1.25mm Fan Connector (5V PWM)
CAN1 x CAN
Multifunctional Port1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC1x RTC 2-Pin
1x RTC Socket (supports CR1220 but not included)
Power9-19V 5525 Barrel DC Jack
MechanicalDimensions (W x D x H)100mm x 80.6mm x 32.5mm
Weight168.0g
InstallationDesk (Copper column include)
Operating Temperature-10℃~60℃
Warranty2 Years
CertificationRoHS,CE,FCC
Hardware Overview
Application
Designed for Developers — Out-of-the-Box Experience:
Whether you're an experienced developer or a complete beginner for embedded AI/GPU inference, use reComputer Super AI box as your first AI workstation, together diving into NVIDIA Jetson for Beginners — your fast track to vision AI, Generative AI, and robotics development! Through these tutorials, you will learn:
  • From Zero to Real Projects: Master Linux basics on the Jetson environment to build an end-to-end AI NVR/AMR.
  • Hardware Integration: Tailored for reComputer Jetson devices for a seamless, out-of-the-box experience.
  • Coverage of Cutting-Edge Domains: Deep dive into CV, GenAI, ROS, agentic AI, and TensorRT optimization.
  • Toolchain Mastery: Hands-on tutorials with NVIDIA JetPack SDK, CUDA, DeepStream, PyTorch, and TensorFlow.
To improve the developer experience, Seeed offers reComputer AI Lab — a platform that helps you deploy AI applications with one-click tools and ready-to-use resources. It includes optimized edge AI model demos for CV, LLM, VLM, interactive tutorials, deployment tools, containerized applications, and community projects to speed up development on Jetson.
Seeed Jetson Develop Tool is a desktop client for all developers who are going to use reComputer Jetson device for the very first time. It brings the common bring-up and development workflow into one GUI: firmware flashing, first-boot initialization, device diagnostics, remote development, app deployment, skill-based automation, OTA updates, and community resources. All we provide here is to help you to get started with Seeed reComputer Jetson hardware much more easily and seamlessly.
Ready to build a solution for the real world? We have Jetson-example prepared for you! It offers one-line deployable projects compatible with generative AI large models, including LeRobot, Ollama, Qwen, etc; with computer vision such as Ultraslytics YOLO26. We have configured all environment setups for you to provide a single command deployment of projects, easy to try out/verify if the trending model performance is suitable for your GPU needs and application scenarios.
Application Fields:
  • AI Video Analytic
  • Machine Vision
  • Autonomous Mobile Robot (AMR)
  • Generative AI
  • Capable of Bringing Generatie AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
  • Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin Nano incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) reComputer J3011 can take 13x1080p30 streams. See our tested YOLOv8 performance using NVIDIA Deepstream of single model and multi model on multi streams.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471800000
COOCHINA
Seeed Carrier Board (reComputer J401)x1
Jetson Orin Nano 8GB Modulex1
256GB SSD (System Installed)x1
Heatsink with Fanx1
Wi-Fi Modulex1
Wi-Fi Antenna Kitx2
19V-4.74A Power Adapter(Barrel Jack 5.5/2.5mm, Power cord not included)x1
AC Cloverleaf Power Cord - US/EU/CNx3
Copper columnx5
Screwx5
reComputer J401 Nano Bundle with Jetson Orin™ Nano 8GB in Super Mode
SKU 100088050
reComputer J401 Nano Bundle with NVIDIA® Jetson™ Orin Nano 8GB platform is a entry level, interface-rich and compact Developer Kit, supporting 67 TOPS AI performance in Super Mode. The Bundle also includes a Wi-Fi combo module, a 256G SSD, and pre-installed JetPack 6.2(supports JP7.2). Its functional design and dimensions are identical to the carrier board of the
NVIDIA® Jetson Orin™ Nano Super Developer Kit.
USD$699.00
