Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Compatible for Jetson AGX Thor Compatible with NVIDIA Jetson AGX Thor™ module
  • 60 degree Ambient Temperature Ensuring module's full performance up to 60 degree celsius ambient temperature
Dimension
169mm x 120mm x 67mm
Rated Voltage
12V
Max air flow
62 CFM
Hardware Overview
Application
  • Put the 6 thermal pads on the heatsink at the following positions in red rectangle areas.
  • There are two foam cubes intended for support of the PCB and heatsink. They need to be taped here at following positions on the bottom side of the reComputer J601 carrier board.
  • The screws shall be inserted from the bottom side of the carrier board to lock the module and the heatsink (from the top side).
For 3D printed stands to hold up carrier board and heatsink, please refer to stl file here (you would need to print 2 of them,slot intended for the copper plate)
Documents
Certification
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8473308000
COOCHINA
Heatsink
x1
Thermal Pad
x5
Screw
x4
reComputer J601 heatsink with fan
SKU 100007973
reComputer J601 heatsink with fan provides powerful cooling for NVIDIA Jetson AGX Thor™ modules, ensuring module‘s performance in up to 60C ambient temerpature (with thermal grease).
USD$69.00
