Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Parameter
Hardware Spec
Product Series
R1000
CPU
Raspberry Pi CM4,  Quad-core Cortex-A72@ 1.5GHz
Operating System
SenseCAP Gateway OS
RAM
4GB
eMMC
32GB
System Spec
Input
2-pin Terminal Block
PoE
IEEE 802.3af Standard 12.95W PoE
Supply Voltage(AC/DC)
12~24V AC/9~36V DC
Overvoltage Protection
40V
Power Consumption
Power Switch
No
Reboot Switch
Yes
Interface
Ethernet
1 x 10/100/1000 Mbps (supports PoE)
1 x 10/100 Mbps IEEE802.3/802.3u
USB
2 x USB-A 2.0 Host
1 x USB-C 2.0 (For flashing OS)
RS485
3 x 3-pin Terminal Block (isolated)
HDMI
1 x HDMI 2.0
SIM Card Slot
supports Standard SIM Card
M.2 Slot
supports M.2 NVMe SSD
LED
6 x LED indicators
Buzzer
1
Reset Button
1
Wireless Communication
LoRa®
SPI LoRa®
Long Range Gateway Chip
SX1302
Channel
8
LoRaWAN® Protocol
V1.1.0 Class A/Class B/Class C
Frequency
902~928MHz
Frequency Plan
US915/AU915/AS923/KR920
Long Range Sensitivity
-125dBm @125KHz/SF7
-139dBm @125KHz/SF12
Long Range TX Power
Up to 26 dBm
Antenna
Long Range: 3dBi External Antenna with Base
Wi-Fi
Support 2.4 GHz/5GHz
Antenna
Wi-Fi & BLE Antenna
4G Cellular
4G LTE*
4G Band
LTE-FDD: B2/4/5/12/13/14/66/71    WCDMA: B2/4/5
Antenna
LTE Antenna
Standards
EMC
ESD: EN61000-4-2, Level 3
EFT: EN61000-4-4, Level 2
Surge: EN61000-4-5, Level 2
Certification
CE, FCC
RoHS
Mechanical
Dimension(W x H x D)
130 mm x 93 mm x 49.6 mm
Enclosure
6061 Aluminum Alloy Casing with Transparent  PC Side Panels
Mounting
DIN-rail/Wall
Weight(Net)
R1225:750g ;R1225 with 4G module:800g
Ambient Conditions
Ingress Protection
IP40
Operating Temperature
-30~70 °C
Operating Humidity
10~95% RH
Storage Temperature
-40~80 °C
Others
Supercapacitor UPS
SuperCAP UPS LTC3350 Module
Hardware Watchdog
1~255s
RTC
High Accuracy RTC
Security
Encryption Chip TPM 2.0*
ATECC608A
Heat Dissipation
Fanless
Warranty
2 years
Production Lifetime
Until at leaset December 2030
Statement
Options marked with * require additional purchase according to the accessories list.
Hardware Overview
The reComputer R1225 have 4GB RAM for processing numerous data points efficiently, along with multiple isolated RS485 channels, versatile interfaces and various wireless communication protocols.
Mini-PCIe1 Slot:Supports 4G LTE, USB Zigbee modules.
  • 4G version pre-installed with LTE module:
    • EU868-4G: EC25-EUX-mini-PCIe (LTE Cat 4)
    • US915-4G: EC25-AFXGA-mini-PCIe (LTE Cat 4)
Mini-PCIe2 Slot: Pre-installed SPI LoRa® module
3x RS485 (isolated) Supports serial communication with isolation for enhanced safety.
1x 10M/100M/1000M Ethernet: Supports Power over Ethernet (PoE) for convenient power delivery over the network cable.
1x 10M/100M Ethernet: Ethernet port for standard network connectivity.
1x HDMI 2.0HDMI port for high-definition video output.
2x Type-A USB 2.0: Standard USB ports for connecting peripherals or storage devices.
1x Type-C USB 2.0: USB- port primarily used for updating the operating system and possibly other functions.
1x SIM Card Slot: Slot for inserting a SIM card, typically used for cellular network connectivity.
1x M.2 Slot: Slot for M.2 expansion cards, allowing for additional functionality or SSD storage option.
This hardware configuration offers a diverse range of connectivity options and expansion possibilities, suitable for various applications requiring communication, networking, and peripheral connections.
Certification
HSCODE8517629990
USHSCODE8517620090
UPC
EUHSCODE8471707000
COO
reComputer R1225 - LoRaWAN gateway
x 1
DIN-rail clip
x 1
Screw Pack
x 1
DC Power Female Jack to Screw Terminal Adapter
x 1
3-pin Terminal Block Connector(Male)
x 3
Wi-Fi & BLE Antenna
x 1
LoRa Antenna
x 1
120Ω Resistor
x 5
User Manual
x 1
reComputer R1225 LoRaWAN Gateway & Industrial Controller (US915), CM4-Powered | 4GB RAM, 32GB eMMC
SKU 100030154
reComputer R1225 is a powerful and flexible industry Raspberry Pi IoT LoRaWAN gateway & controller, CM4-powered, with AI capabilities. With 3*RS485, dual-ethernets, BACnet, and Modbus support, equipped with all the necessary features that a robust and reliable industrial edge IoT device needs. With compatibility with AI NPU accelerator, it's a perfect fit for remote access control, especially BMS, BAS, and iBMS.
Region
Network Connection
USD$400.00
