Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
  • Robust Hardware Design: A compact, high-performance edge AI computer with NVIDIA Jetson Orin Nano 8GB module in Super/MAXN mode, providing up to 67 TOPS of AI performance.
  • Multiple Interfaces for robotics: Including dual RJ45, M.2 slots for 5G/Wi-Fi/BT modules, 6x USB 3.2, 2x CAN, GMSL2(additional purchase), I2C, and UART, functioning as a powerful robotic brain.
  • Software Setup: Pre-installed with JetPack 6.2 and Linux BSP for seamless deployment.
  • Application and Benefit: Ideal for rapid development of autonomous robots, accelerating time-to-market with ready-to-use interfaces and optimized AI frameworks.
  • Wide Operating Range: Operates reliably across a temperature range of -20°C to 60°C at 25W mode
    Jetson Modules Performance with Super Mode
    • Enhanced power management
    • Improved higher frame rate processing
    • Reduced inference time
Module
reComputer Robotics J3011
Applications Processor(AP)
NVIDIA Jetson Orin™ Nano 8GB
AI Performance
Orin Nano 8GB – 67 TOPS (MAXN)
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
GPU Max Frequency
1020 MHz (MAXN_SUPER)
CPU
6-core Arm® Cortex®-A78AE
CPU Max Frequency
1.7 GHz (MAXN_SUPER)
Memory
8GB 128-bit wide LPDDR5 DRAM(up to 68GB/s; 102 GB/s MAXN_SUPER)
Power
7W - 15W - 25W
Video Encode
1080p30 supported by 1-2 CPU cores
Video Decode
1x 4K60 (H.265)
2x 4K30 (H.265)
5x 1080p60 (H.265)
11x 1080p30 (H.265)
CSI camera
Up to 4 cameras
(8 via virtual channels)
8 lanes MIPI CSI-2
D-PHY 2.1 (up to 20Gbps)
Mechanical
69.6mm x 45mm
260-pin SO-DIMM connector
Carrier Board
Storage
1x M.2 KEY M PCIe
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
M.2 KEY B
1x M.2 Key B for 5G module
Ethernet
2x RJ-45 Gigabit Ethernet
I/O
USB
6x USB 3.2 Type-A (5Gbps)
1x USB 3.0 Type-C (Host/DP 1.4)
1x USB 2.0 Type-C (Device Mode Only for Reflash/Debug)
CAN
2x CAN0 (XT30(2+2))
3x CAN1 (4-Pin GH-1.25 Header)
Display
1x DP1.4 (Type C Host)
UART
1 x UART 4-Pin GH-1.25 Header
I2C
2x I2C 4-Pin GH-1.25 Header
Fan
1x 4-Pin Fan Connector (5V PWM)
1x 4-Pin Fan Connector (12V PWM)
Extension Port
1x Camera Expansion Header (for GMSL2 board, not included)
RTC
1x RTC 2-pin
1x RTC Socket
LED
3x LED (PWR, ACT and User LED)
Pinhole Button
1x PWR
1x RESET
DIP Switch
1x REC
Antenna Hole
5x Antenna Hole
Power
19-54V XT30(2+2) (XT30 to 5525 DC Jack Cable included)
Jetpack Version
Jetpack 6.2
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 66mm
Weight
1100g
Installation
Desk, Wall-mounting
Operating Temperature
-20℃~60℃ (25W Mode)
-20℃~55℃ (MAXN Mode)
(with reComputer Robotics heat sink with fan)
Warranty
2 Years
Certification(Pending)
RoHS, REACH, CE, FCC, KC
Hardware Overview
Application
The NVIDIA AI software stack is designed for accelerate AI application and deployment:
Designed for Edge AI Computer Vision Applications:
Jetson Platform Services provide a platform to simplify development, deployment and management of Edge AI applications on NVIDIA Jetson like BEV sensing demo with 4 USB cameras.
Designed for demanding AI applications:
Such as AMR, smart retail, industrial automation, and video surveillance, smart video analysis scenario
The NVIDIA Isaac™ platform delivers the NVIDIA® CUDA®-accelerated libraries, application frameworks, and AI models you need to create autonomous mobile robots (AMRs), arms and manipulators, humanoids, and more.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
Items
Quantity
Jetson Orin™ Nano 8GB module
x 1
Seeed Carrier Board (reComputer Robotics J401)
x 1
128GB NVMe SSD
x 1
Aluminum Case and Heatsink with Fan
x 1
USB Cable; Type A to Type C
x 1
XT30 to DC cable
x1
User Manual
x 1
reComputer Robotics J3011 - Intelligent Edge AI Computer with NVIDIA Jetson Orin Nano Super 8GB
SKU 114110308
The reComputer Robotics J3011 is a compact, high-performance edge AI box designed for advanced robotics development. Compatible with NVIDIA® Jetson™ Orin™ modules in Super/MAXN mode, it delivers up to 67 TOPS of AI performance, leveraging up to 1.7x improvement over its predecessor. Pre-installed with JetPack 6.2 and Linux BSP, it ensures seamless deployment, serving as a powerful robotic brain capable of processing complex data from various sensors.
Series
Processor
Memory
GMSL
USD$789.00
