Loading...
Multi Chassis Tank (Rescue Version) Robot Platform
Rating:
100% of 100
The Multi Chassis Tank Rescue Platform is specially designed for rugged terrains
$199.00
Out of stock
  • 10+: $179.10
  • 20+: $169.15
  • More
  • 50+: $159.20
  • Less
The Multi Chassis Tank Rescue Platform is specially designed for rugged terrains. It equipped with two independently controlled articulated arms. The arms can help it to server in all kinds of terrains, include flat mattess, ground, smooth ceramic tile, lawn and so on.
The robot can easily across the low barrier, automatically adjust the angle of assistant-track to pass the way. To rise up and down the assistant-track, the robot can pass stairs easily and smoothly. More details about the features of the Multi Chassis Tank Rescue Platform you can find in the video.
  • Serve in all kinds of rugged terrains
  • Independently controlled articulated arms
  • Size: 262*222*60mm( length*width*height )
  • Wheel diameter:Φ52mm
  • Track wheel :8pcs
  • DG01D 48:1 DC Motor: 2pcs (Metal output shaft)
  • NET Weight:800g
Docuemnts
Dimensions 240mm x160mm x100mm
Weight G.W 990g
Battery Exclude
HSCODE 9023009000
UPC 841454105633
ROHS 1
Documentations
Learn
  1. Rating
    100%
    By
1 Item
Show per page
