Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • An Ultra-Compact Smart Device Board
    With a board width of only 18.8 mm, this is the most compact model in the lineup. It brings display, motion sensing, audio input, physical buttons, battery support, Wi-Fi, and Bluetooth connectivity into a form factor that remains as narrow as the XIAO board itself, making it easier to build compact enclosures, badges, pendants, and portable devices.
  • Essential Information on a Tiny Color Display
    The 0.96-inch 80 × 160 IPS display is ideal for showing essential information such as connection status, sensor readings, counters, icons, battery voltage, notifications, and simple menus. It gives tiny projects a clear visual interface while keeping the overall device extremely compact.
  • Voice, Motion, and Two-Button Interaction
    The onboard PDM microphone lets your project react to sound and capture audio data, while the 6-axis IMU detects orientation, shaking, flipping, and movement. Two physical buttons provide simple and reliable user input, allowing you to build interactive devices without adding external modules.
  • Wi-Fi and Bluetooth in a 17.8 mm-Wide Form Factor
    Powered by XIAO ESP32-S3 Plus, this compact board combines a dual-core processor running at up to 240 MHz with Wi-Fi, Bluetooth Low Energy, 8 MB PSRAM, and 16 MB Flash. This makes it possible to build tiny connected dashboards, notification devices, sensor nodes, and portable interfaces while keeping the hardware footprint small.
SpecificationXIAO 1.47'' IPS Display(ESP32-S3)XIAO 1.14'' IPS Display(ESP32-S3)XIAO 0.96'' IPS Display(ESP32-S3)
PositioningTouch & Full InteractionSensing & ExpansionUltra-Compact
Core ControllerSeeed Studio XIAO ESP32-S3 Plus
ProcessorESP32-S3R8, Dual-Core, up to 240 MHz
Memory8 MB PSRAM + 16 MB Flash
Wireless2.4 GHz Wi-Fi + BLE 5.0
Display1.47" IPS TFT1.14" IPS TFT0.96" IPS TFT
Resolution172 × 320135 × 24080 × 160
Display DriverJD9853AST7789ST7789
TouchCapacitive TouchNoNo
6-Axis IMUYes
PDM Digital MicrophoneYes
MicroSD Card SlotYesNoNo
Grove I2C ConnectorNoYesNo
User Buttons232
Battery Connector2-pin JST, 3.7 V LiPo
Battery MonitoringBattery voltage monitoring via D16 ADC; battery level can be estimated from the measured voltage.
Battery status detection is not supported.
Expansion Interfaces1x I2C Interface
1x I2S Interface
1x JTAG Interface
2x User Button Interface
1x I2C Interface
1x I2S Interface
1x JTAG Interface
3x User Button Interface
1x I2C Interface
1x I2S Interface
1x JTAG Interface
Board Size26.4 × 51.4 × 12.6 mm26 × 48 × 10.6 mm18.8 × 43.6 × 10.6 mm
Best ForTouch UI, portable HMI, local media & data loggingSensor dashboards, Grove projects, physical controllersTiny IoT devices, wearables, status displays
Hardware Overview
  • Onboard
Application
  • Mini Desktop Dashboard
  • AI Voice Assistant & Agent Terminal Prototype
  • Smart Home Touch Controller
  • Digital Pet and Interactive Toy
Certification
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
XIAO 0.96'' IPS Display(ESP32-S3)×1
2.4GHz FPC Antenna A-02 for XIAO ESP32-S3×1
SKU 100037468
It is an ultra-compact mini smart device development board built around the pre-soldered XIAO ESP32-S3 Plus. With a board width of only 18.8 mm, it integrates a 0.96-inch IPS display, PDM digital microphone, 6-axis IMU, two user buttons, battery connector, Wi-Fi, and Bluetooth connectivity into a tiny form factor.
It is especially suitable for compact status displays, wearable prototypes, mini IoT controllers, motion-aware devices, digital pets, and other projects where size matters.
XIAO Dev Board
Display Size
USD$15.90
