Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • 4x USB 3.0 Ports - Connect up to four USB devices at USB 3.0 speeds (up to 5 Gbps) from a single host port.
  • Industrial-Grade Design - Built for dependable performance in industrial, embedded, and other demanding environments.
  • USB-A Host Connection - Plugs directly into your computer's USB-A port with a 0.3 m cable for a tidy, low-profile setup.
  • RoHS Certified - Compliant with RoHS environmental requirements (certificate attached in the Product Documents section below).
Application
Expand a single USB-A port into four USB 3.0 ports for peripherals such as flash drives, external storage, keyboards, mice, printers, and USB tools.
Designed for personal PCs, embedded systems, test benches, data-acquisition setups, and automation equipment that need dependable multi-device connectivity.
Ideal for adding high-speed USB ports to servers, workstations, and development kits with limited built-in ports.
Certification
HSCODE8517623500
USHSCODE8517620090
UPC
EUHSCODE8517620000
COOCHINA
4-Port USB 3.0 Hub-USB-Cx1
4-Port USB 3.0 Hub - USB-A
SKU 100015890
All 4 ports are USB 3.0 with an industrial-grade design and a USB-A host connection to your computer.
4-Port USB 3.0 Hub - USB-C
USD$16.00
