ATX Breakout Board V1.1 Acrylic Case V1 (DP10080)
A clear laser-cut acrylic case kit for the ATX Breakout Board v1
- 10+: $3.60
- 20+: $3.40
- More
- 50+: $3.20
- Less
A clear laser-cut acrylic case kit for the ATX Breakout Board v1.1. This case is designed to be simple, cheap, and easy to assemble. The ATX Breakout Board is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions | 0mm x0mm x0mm |
Weight | G.W 61g |
HSCODE | 3926909090 |
USHSCODE | 3926100000 |
UPC | 841454111917 |
EUHSCODE | 3926909705 |
COO | CHINA |
RoHS | 1 |
Good enclosure
