Crazyflie 2.0 - LED-ring Expansion Board
SKU 114990114
20.00
38 Available
$20.00/ 1pcs+
$18.00/ 10pcs+
$17.00/ 20pcs+
Light up the dark with custom patterns using the Crazyflie 2.0 LED-ring expansion board. Featuring 12 strong RGB LEDs facing downwards, you can create custom patterns in firmware that you control from your Android/iPhone or computer. Two additional strong front facing LEDs that can be switched on and off, act as headlights.
This product is intended to be used together with the Crazyflie 2.0 nano quadcopter and uses its expansion board system. Please have a look at the buyers guide for more info about Crazyflie 2.0 expansion boards.
  • DC-DC step-up/down gives stable LED light independant of battery voltage
  • Create custom patterns using the Crazyflie 2.0 firmware
  • 12 RGB LED modules facing downwards
  • 2 strong LEDs facing forward
  • Automatic detection of expansion board using 1-wire memory
  • DC-DC step-up/down gives up to 1A at 3.8V from input between 2-5.5V
  • 12 independantly addressable RGB LED modules facing downwards ()
  • 2 strong white LEDs facing forward
  • 1-wire memory for automatic expansion board detection
  • Designed for mounting under the Crazyflie facing downwards
  • ¬üMechanical specification:
  • Weight: 3.3g
  • Size (WxHxD): 33x33x5.5mm
Tech Support
If you have any further question for technical support, please contact support@bitcraze.io
Related Products
Crazyflie 2.0Crazyradio PA - long range 2.4Ghz USB radio dongle with antennaCrazyflie 2.0 debug   adapter kitCrazyflie 2.0 - Buzzer deck
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 5g
BatteryExclude
LED-ring expansion1
ECCNNot Available
HSCODE9405990000
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 114990114
    $20.00
    38 Available
    $20.00/ 1pcs+
    $18.00/ 10pcs+
    $17.00/ 20pcs+
    • Description
    • Bundle sales
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
