EMW3166 WiFi Module
Esp32, combo, wireless, Wi-Fi, wifi, emw3162, emw3239, emw3165, emw3166, esp8266, mxchip, nrf52840, smart
Special Price $6.90 Regular Price $9.95
In stock
EMW3166 is one embedded Wi-Fi module of low-power, small-size and low-cost designed by MXCHIP. It integrates one Cortex-M4 microcontroller of 256Kbytes SRAM and 1Mbytes on-chip flash with another 2Mbytes on-board SPI flash added. Various peripheral interfaces of analog and digital are available. The power supply voltage is 3.3V. It applies half-hole footprint for hand-soldering. The module runs MICO, which is the IOT OS System of MXCHIP, and is available for secondary development. The TCP/IP protocols and security encryption algorithm could be applied in various Wi-Fi applications. In addition, several particular firmware prepares for some typical applications, like UART to Wi-Fi DTU, easylink configuration and services for cloud interfacing.
Feature
Properties
  • Integration of one Cortex-M4 MCU and one RF chip of 802.11 b/g/n
  • Cortex-M4 core at 100MHz
  • 2M bytes on-board SPI flash and 1M bytes on-chip flash
  • 256K bytes SRAM
Operation voltage
  • Low voltage mode: 2.3~3.0V
  • Normal voltage mode: 3~3.6V
Peripherals
  • 25 GPIOS
  • JTAG/SWD debug interfaces
  • Wi-Fi connectivity:
  • 802.11 b/g/n available
  • WEP, WPA/WPA2, PSK available
  • 16.5dBm@802.11b, 14.5dBm@802.11g, 13.5dBm@802.11n
  • Receiver Sensitivity: -87dBm
  • Station, Soft AP and Wi-Fi Direct
  • Easylink available
  • On-board PCB antenna and IPEX connector for external antenna
  • CE, FCC compliant
Operation Temperature
  • -30°C~+85°C
Application scenarios
  • Auto electronics
  • Point of Sale system
  • Industrial automation systems
  • Medical/Health care
  • Smart home appliances
  • Smart LED
Dimensions 32mm x16mm x3mm
Weight G.W 3g
Battery Exclude
EMW3166 WiFi Module(External IPEX antenna) 1
ECCN 5A002.a
HSCODE 8517709000
USHSCODE 8517700000
Product Faqs
Sort by
