Ai Thinker A1S Wi-Fi+BT Audio Development Kit
SKU 107990093
16.90
DISCONTINUED
Sorry but this SKU# 107990093 is unavailable from Seeed now.
You can buy it from the original manufacture or other distributors.
The unfilled orders will be shipped out on 9th Nov.
For the technical support, pls feel free to contact Seeed or ask the original manufacture for help.
Thanks.
Technical Details
Dimensions65mm x 58mm x 10mm
WeightG.W 30g
BatteryExclude
CPU Xtensa® 32-bit LX6 dual-core processor,Summary computing power up to 600 DMIPS
ROM 520KB SRAM RTC 16 KB SRAM
IO port 10
Package DIP-16
SPI Flash Default 32Mbit
RAM 520KB SRAM+8M PSRAM
Support interface URAT,SPI,I2C,PWM
Support TF card Maximum support 64G
UART Baudrate Default 115200 bps
Audio Output Support 1 channel headphone output and 1 channel left and right speaker output
Audio Input Support LINEIN and 2-way MIC input
Spectrum range 2412~2484MHz
WiFi 802.11 b/g/n/d/e/i/k/r (802.11n, speed up to 150Mbps) A-MPDU and A-MSDU aggregation, support 0.4μs guard interval 2.4~2.5GHz
Bluetooth Bluetooth 4.2 BR/EDR and BLE standards, NZIF receiver with -98 dBm sensitivity, support AFH (Adaptive Frequency Hopping), support CVSD and SBC audio formats
Power Supply 5V 2A
Ai Thinker -A1S Wi-Fi+BT Audio Development Kit1
ECCN5A002.a.1
HSCODE8522909900
Reviews
Questions and Answers
SUBMIT
1
I don't see audio specs, and I don't see any audio chips (i2s or otherwise) on the board. Does this imply that all audio goes through the esp32 8bit DACs? That would seriously limit the quality and therefore the usefulness of this board...
on Oct 17,2018
Reply upvote ()
AC101 is integrated into the ESP32-A1S. thanks.
on Oct 17,2018 15:32 PM
Reply upvote ()
Reply
1
Hi there! On the SCH, the designators are not numbered; all are reset to question marks (?). Also, no part numbers or values are indicated. Are you going to fix it? Are you going to share the BOM?
on Oct 16,2018
Reply upvote ()
Hi there, please refer to **https://github.com/SeeedDocument/forum_doc/blob/master/reg/ESP32-Audio-Kit_V2.1-Audio.pdf** and **https://github.com/SeeedDocument/forum_doc/raw/master/reg/ESP32-Audio-Kit_V2.1-Power.pdf**. For the BOM, we do not have a plan to release yet. thanks.
on Oct 17,2018 16:35 PM
Reply upvote ()
Reply
1
Are the audio inputs / outputs balanced or unbalanced?
on Oct 16,2018
Reply upvote ()
    View History
    SKU 107990093
    $16.90
    DISCONTINUED
    $16.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
