$59.90
In stock
2 Available
Qty Discount available
  • $53.91 /10pcs+
  • $50.92 /20pcs+
  • $47.92 /50pcs+
This is version 3.0 of GPRS Shield.
Hook your Arduino up to GSM/GPRS cell phone network with GPRS shield! You can use your Arduino/Seeeduino or other main boards to dial a phone number or send a text to your friend via easy to use AT commands now.
GPRS Shield features a quad-band low power consumption GSM/GPRS module SIM900 as well as a compact PCB antenna.Meanwhile, improvements on interfaces and basic circuit have been taken to make it more concise and reliable.
And there’re two choices for you to communicate GPRS shield with the main board -- UART or SoftwareSerial.
The difference between this version and the previous version is, changing the arduino socket to the latest Arduino Uno standard. Except this, all the features are same with the previous version.
  • Compatible with standard Arduino and Arduino Mega
  • Selectable interface between hardware serial port and software serial port
  • Quad band support: 850/900/1800/1900MHz
  • Support TCP/UDP protocols
  • Full control via AT commands set: Standard - GSM 07.07 & 07.05 and Enhanced - SIMCOM AT Commands
  • 2-in-1 headset jack
  • Convenient external SIM card holder
  • Low power consumption: 1.5mA(sleep mode)
  • Compatible:Arduino UNO/Seeeduino directly ; Other main board via jumpers;
  • Selectable interface:UART, Software seria;
  • Quad band support:850/900/1800/1900MHz;
  • Communication support:Standard - GSM 07.07 & 07.05 and Enhanced - SIMCOM AT Commands;
  • Operation temperature:-40°C to +85 °C;
  • Protocol support:0710 MUX protocol, embedded TCP/UDP protocol, FTP/HTTP, FOTA, MMS, embedded AT;
  • Certification of SIM900:CE, IC, FCC, ROHS, PTCRB, GCF, ICASA, REACH, AT&T
  • Dimensions: 68.58 * 53.34mm;
  • Power supply:5v via 5V pin, 6.5~12v via Vin pin;
Dimensions 100mm x65mm x30mm
Weight G.W 47g
Battery Exclude
Compatible Arduino UNO/Seeeduino directly ; Other main board via jumpers
Selectable interface UART, Software seria
Quad band support 850/900/1800/1900MHz
Communication support Standard - GSM 07.07 & 07.05 and Enhanced - SIMCOM AT Commands
Operation temperature -40°C to +85 °C
Protocol support 0710 MUX protocol, embedded TCP/UDP protocol, FTP/HTTP, FOTA, MMS, embedded AT
Certification of SIM900 CE, IC, FCC, ROHS, PTCRB, GCF, ICASA, REACH, AT&T
Dimensions 68.58 * 53.34mm
Power supply 5v via 5V pin, 6.5~12v via Vin pin
GPRS Shield V3.0 1
ECCN 5A991.b
HSCODE 8517709000
USHSCODE 8517700000
UPC 841454109006
GPRS Shield V3.0
Product Faqs
Sort by
  • Would it work with the Netduino2+ board? As my COM1 port is already in use can I select another UART (COM2,COM3) but not the software serial? And finally does it suport LTE NB-IoT?
    Question by: Igor on 2018-12-19 19:22:45
    Hi there, yes, you can remove the cap from the J4 connector, then you use the jumper wire and connect the middle 2 pins of J4 connector to your related COM2/COM3 pins. thanks.
    Answer by: admin on 2019-01-09 04:40:40
  • Question by: admin on 2018-12-18 02:32:05
    Sorry,we would like to help you with this ,but saddly we can't. If you want to experience the new version,just buy it. :D
    Answer by: admin on 2018-12-18 02:32:05
  • Question by: admin on 2018-12-18 02:30:23
    Hi there~ Yes you can get the latitude and longitude. Please refer to here # http://wiki.seeed.cc/GPRS_Shield_V2.0/ # Regards
    Answer by: admin on 2018-12-18 02:30:23
  • Question by: admin on 2018-12-18 02:30:02
    Hi~The working current of this shield is about 80mA. When you use this shield to make a call, it can be around 290mA.Regards
    Answer by: admin on 2018-12-18 02:30:02
Tags:
