seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Grove - 3-Axis Digital Compass
      SKU 101020034
      $14.90
      21 Available
      $14.90/1pcs+
      $13.41/10pcs+
      $12.66/20pcs+
      $11.92/50pcs+
      ADD TO CART
      3-Axis Compass module, a member of grove family uses I²C based Honeywell HMC5883L digital compass. This ASIC is equipped with high resolution HMC118X magneto-resistive sensors and a 12-bit ADC. It provides compass heading accuracy up to 1° to 2°. Signal conditioning like amplification, automatic degaussing strap drivers and offset cancellation are inbuilt. This grove module also includes a MIC5205-3.3 for power supply requirement. Hence user can connect any 3.3V to 6V DC power supply.
      • Grove compatible interface
      • 3-Axis Magneto-resistive type sensors
      • I²C serial interface
      • 1° to 2° Degree heading accuracy
      • Up to 116 Hz Maximum output rate
      • Built-In self test
      Technical Details
      Dimensions20mm x 20mm x 15mm
      WeightG.W 6g
      BatteryExclude
      Grove - 3-Axis Compass V1.01
      Grove Cable1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hi, I am planning to use two of the digital compass sensors on the same GrovePi. Will it work? Or how to make them both individually adressable?
      on Dec 25,2016
      Replyupvote ()
      Hello, you can't use 2 I2C modules in one GrovePi, as they have same address.And the address of this module is not selectable.Thanks.
      on Jan 09,2018 16:13 PM
      Replyupvote ()
      Reply
      0
      Hi. I'm currently using multiple GoPiGos and each have their own compass sensor. They all work, however are all showing very inconsistent data. Is the some sort of calibration that we can do when using these for the GoPiGos? Thanks!
      on Nov 29,2016
      Replyupvote ()
      Hello, it's ±5V or ±10V (selectable)
      on Jan 09,2018 16:17 PM
      Replyupvote ()
      Reply
      0
      Here is a JavaScript library that I have developed for this compass: https://github.com/psiphi75/co... . I have used it on a BeagleBone Green with success. See this project for
      on Oct 19,2016
      Replyupvote ()
      <p>It is ok to do that. You can use solar panel or other power source to supply the board through solar cell input.</p>
      on Oct 20,2016 10:40 AM
      Replyupvote ()
      Reply
      0
      Hi!
      I load (and unzip) all programs from your wiki page for this Grove module to arduino-1.0.1\libraries.
      Files is not open by arduino-1.0.1, because file extention of your files is not compatible with arduino-1.0.1.
      What is wrong?
      on Oct 19,2016
      Replyupvote ()
      <p>Hi,maybe you could change a browser and have a try,things like that(<a href="http://www.seeedstudio.com/forum/viewtopic.php?f=23&t=4322)" rel="nofollow">http://www.seeedstudio.com/for...</a>.</p>
      on Oct 20,2016 10:45 AM
      Replyupvote ()
      Reply
      0
      Could i connect that wonderful device directly to an I2C bis with 5V logic level without a logic level shifter?!
      on Oct 19,2016
      Replyupvote ()
      <p>hi,there is already a logic level shifter in our product. if you do your products with this IC, please refer to the datasheet.</p>
      on Oct 20,2016 10:43 AM
      Replyupvote ()
      Reply
      0
      i connect it direct to the ardurino and its not working
      http://www.seeedstudio.com/wik...
      i use this link and download the soft to the board
      on Oct 19,2016
      Replyupvote ()
      <p>Hello, there is something wrong with the code, we have modified it, please kindly copy the code and upload to your Arduino again :D</p>
      Replyupvote ()
      Reply
        View History
        SKU 101020034
        $14.90
        21 Available
        ADD TO CART
        $14.90/1pcs+
        $13.41/10pcs+
        $12.66/20pcs+
        $11.92/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
