the AI Hardware Partner
Toggle Nav
Loading...
Grove - High Temperature Sensor
Thermocouples are very sensitive, requiring a good amplifier with a cold - compensation reference
$17.90
In stock
  • 10+: $14.20
Thermocouples are very sensitive, requiring a good amplifier with a cold - compensation reference. The Grove - Temperature Sensor USES a K-type thermocouple Temperature detection, with a Thermistor to detect The ambient Temperature as Temperature compensation. The detectable range of this Sensor is -50-600℃, and The accuracy is ±(2.0% + 2℃)
Specifications
  • Voltage:3.3 ~ 5V
  • Max power rating at 25℃:300mW
  • Operating temperature range:-40 ~ +125 ℃
  • The temperature measurement range is (-50 ~ +600℃)
  • Amplifier output voltage range (0 ~ 3.3 V) mv
  • Cold junction compensation (environment temperature measurement)
  • Thermocouple temperature measurement accuracy of + / - 2.0% (+ 2 ℃)
Get Started with Industrial Sensors
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2101 Wireless Temperature and Humidity Sensor with higher performance and robustness for air temperature and humidity detection.
Upgrade to Industrial Solutions
Package Include:
  • Grove - High Temperature Sensor x1
  • Thermocouple Temperature Sensor x1
  • 24AWG Grove Cable - 4P-4P-2.0-200mm x1
Dimensions 110mm x85mm x12.5mm
Weight G.W 30g
Battery Exclude
Grove - High Temperature Sensor 1
HSCODE 9025900090
USHSCODE 9026104000
UPC 841454108245
EUHSCODE 9013101000
COO CHINA
EU DoC 1
RoHS 1
UK DoC 1
