Grove - Gesture Sensor for Arduino (PAJ7620U2)
The sensor on Grove - Gesture is PAJ7620U2 that integrates gesture recognition function with general I2C interface into a single chip
- 10+: $7.90
Grove - Gesture is based on PAJ7620U2 that integrates gesture recognition function with general I2C interface into a single chip. It can recognize 9 gestures including moving up, moving down, moving left, moving right, etc with a simple swipe by your hand.
Following is a video which using Gesture sensor with a matrix to display the direction of the hand.
We can use the gesture to adjust the sound volume, control a robot. We can also make a remote-control unit, which is able to operate many devices at the same time using gestures
FEATURES
9 gestures recognition
Built-in proximity detection
Various mainboards support: Arduino UNO/Seeeduino/Arduino Mega2560
PART LIST
1x PCBA-Grove - Gesture
1x 26AWG Grove Cable;SA206120099A
SPECIFICATIONS
Interface: IIC
13 gesture recognition
Operating Power:5V
Dimensions:20*20mm
Sensor: PAJ7620U2
Detecting range: 5 – 10cm
Ambient light immunity: < 100k Lux
Gesture speed mode: Normal and Gaming
What is Grove?
Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumpers or soldering required. We have developed more than 300 Grove modules, covering a wide range of applications that can fulfill a variety of needs. Not only are these open hardware, but we also have open-source software.
We've done all the hard work with example code and software libraries to help you to started with this sensor in just a few lines of code. Check our Wiki to learn more!
Note
We've Released the Grove Selection Guide and hope to help you find the Grove suit you best.
Dimensions | 110mm x75mm x9mm |
Weight | G.W 9g |
Grove - Gesture | 1 |
HSCODE | 9031900090 |
USHSCODE | 9026104000 |
UPC | 841454108306 |
EUHSCODE | 9013101000 |
COO | CHINA |
EU DoC | 1 |
RoHS | 1 |
UK DoC | 1 |
Documentations
from order viewgood product
from order viewThis user did not leave any comments.
