Grove - Temperature & Humidity Sensor (DHT11)
Grove - DHT11 Temperature & Humidity Sensor is a high quality, low-cost digital temperature, and humidity sensor based on the DHT11 module.
Grove - Temperature & Humidity Sensor uses the upgraded version of DHT11. The new version of the DHT11 module replaces resistive humidity components with capacitive humidity components. The temperature and humidity measurement range are wider. The temperature resolution is higher.
^ BACK TO TOP
- Full range temperature compensation calibrated
- Single bus digital output
- High precision capacitive humidity sensor
- Long transmission distance and excellent long-term stability
- Low power consumption
- Cost-effective
DHT11 is the most common temperature and humidity module for Arduino and Raspberry Pi. It is widely favored by hardware enthusiasts for its many advantages such as low power consumption and excellent long-term stability. Relatively high measurement accuracy can be obtained at a very low cost. The single-bus digital signal is output through the built-in ADC, which saves the I/O resources of the control board.
On top of that, Grove - Temperature & Humidity Sensor uses the upgraded version of DHT11. The new version of the DHT11 module replaces resistive humidity components with capacitive humidity components. The temperature and humidity measurement range are wider. The temperature resolution is higher. You can check the following figure for more detail.
Comparison between DHT11 and DHT22
There is another famous DHT sensor on our website -- Grove DHT22. Compared with DHT22, the DHT11 sensor is more cost-effective, but the measurement range and accuracy are lower. The Grove DHT11 can be a low-cost alternative to the Grove DHT22 when accuracy requirements are not as high. Please refer to the following table for the difference between those two:
ITEM | Grove - DHT11 | Grove - DHT22 |
Humidity | ||
Range | 5 ~ 95%RH | 0 ~ 100%RH |
Accuracy | ±5% (Typical) | ±2% (Typical) |
Temperature | ||
Range | -20 ~ 60℃ | -40 ~ 80℃ |
Accuracy | ±2% (Typical) | ±0.5% (Typical) |
Applications
- Weather station
- Automatic control
- Testing and inspection equipment
Hardware Overview
Dimensions | 40mm x20mm x8mm |
Weight | G.W 10g |
Input Voltage | 3.3V & 5V |
Measuring Current | 1.3 - 2.1 mA |
Measuring Humidity Range | 5% - 95% RH |
Measuring Temperature Range | -20 - 60 ℃ |
Grove - Temperature & Humidity Sensor | 1 |
Grove Cable | 1 |
HSCODE | 9025900090 |
USHSCODE | 9031808070 |
UPC | 841454107552 |
ROHS | 1 |
Documentations
Learn
Make your own humidifier or scent dispenser using Seeeduino Nano + Grove Water Atomization, keep track of the current humidity with DHT11
With so many temperature sensors available, how should we choose the right one for our Arduino project? Well, it really depends on several factors such as what we are measuring, the degree of accuracy we need and where we may be measuring the temperature.
Different temperature and humidity sensors have large performance differences and large price differences. So how to choose the most suitable sensor for your project?
Looking for low-cost temperature and humidity sensors? DHT11 and DHT22 are the most common temperature and humidity modules for Arduino and Raspberry Pi. DHT sensors will be perfect for you. Despite being slower than other temperature sensors, they have advantages including low power consumption and excellent long-term stability.
A cube with all the necessary sensors, suitable for a wide range of applications like agriculture. Know the land beneath you!
Using the system multiple persons can share a single toilet efficiently.
Biofloc fish project monitoring. Water quality maintenance and monitoring in any aquaculture are the essential practices aiming at the success of the growing cycles.
Using Arduino and the sensors I analyzed how a small air humidifier can change the parameters of the room and influence the health state.
This temperature & humidity sensor provides a pre-calibrated digital output. A unique capacitive sensor element measures relative humidity and the temperature is measured by a negative temperature coefficient (NTC) thermistor. It has excellent reliability
from order viewThis user did not leave any comments
from order viewThis user did not leave any comments.
accurateI was surprised by how sensitive it was to the temp from just my fingers.
it’s greatI bought this humidity to monitor my grow tent and it’s great
OKGreat Service, quality Product
