seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      GrovePi+
      GrovePi+
      SKU 103010002
      $29.99
      11 Available
      $29.99/1pcs+
      $26.99/10pcs+
      ADD TO CART
      GrovePi+ are compatible with Pi 2, please check the details from Dexter'sblog.
      GrovePi+
      What is GrovePi+
      GrovePi+ is add-on board with 15 Grove 4-pin interfaces that brings Grove sensors to the Raspberry Pi. It is the newest version compatible with Raspberry Pi model B/B+/A+/2/3 perfectly.
      GrovePi+ is an easy-to-use and modular system for hardware hacking with the Raspberry Pi, no need for soldering or breadboards: plug in your Grove sensors and start programming directly. Grove is an easy to use collection of more than 100 inexpensive plug-and-play modules that sense and control the physical world. By connecting Grove Sensors to Raspberry Pi, it empowers your Pi in the physical world. With hundreds of sensors to choose from Grove families, the possibilities for interaction are endless.
      NOTE: The Raspberry Pi board  is not included.
      What is New
      • Compatible with Raspberry Pi model B/B+/A+/2/3 perfectly
      • Faster SPI and higher reliability UART connections
      • Easier to assemble camera cables and LCD cables
      • Simplified procedures of firmware update
      How to use
      • Step 1 - Slip the GrovePi+ board over your Raspberry Pi
      • Step 2 - Connect the Grove modules to the GrovePi+ board
      • Step 3 - Upload your program to Raspberry Pi
      • Step 4 - Begin taking in the world data
      Technical Details
      Dimensions88mm x 58mm x 23mm
      WeightG.W 51g
      BatteryExclude
      7 digital Ports
      3 analog Ports
      3 I2C ports
      1 Serial port connect to GrovePi
      1 Serial port connect to Raspberry Pi
      Grove header Vcc output Voltage5Vdc
      Grove Pi+1
      Reviews
      Questions and Answers
      SUBMIT
      0
      does it work with pi 3?
      on Jun 07,2017
      Replyupvote ()
      Yes,it is compatible,you can use it with pi 3
      on Sep 02,2017 14:13 PM
      Replyupvote ()
      Reply
      0
      The Pi can run more than one program at once. Since I do not know what Pi GPIO pins are taken, does the Grove limit the Pi to running "Grove only tasks"? Are the balance of the Pi's pins still usable for other things? Thanks...
      on Oct 21,2017
      Replyupvote ()
      Hi Dear Customer, GPIO 04,17,21,2225,24,23,18 are free. For more info, please refer to schematic. https://github.com/SeeedDocument/GrovePi_Plus/raw/master/res/GrovePi%2B%20v3.0%20Sch.pdf thanks Bill
      on Jan 17,2018 16:15 PM
      Replyupvote ()
      Reply
      0
      It's compatible with pi 2? Thanks!
      on Oct 19,2016
      Replyupvote ()
      <p>Please notice that there is a firmware variant of the latest version that not requires calibration when upgrading. The file "<a href="http://SARK110-VAA-APP0.7.2a.dfu.zip" rel="nofollow">SARK110-VAA-APP0.7.2a.dfu.zip</a>" is available in the firmware s
      on Oct 20,2016 10:44 AM
      Replyupvote ()
      <p>It is compatible with Pi 2.</p><p>We will update the description later.</p>
      on Oct 20,2016 10:50 AM
      Replyupvote ()
      <p>Dexter post a blog about it, you can check more details in here:<a href="http://www.dexterindustries.com/site/?p=5524" rel="nofollow">http://www.dexterindustries.co...</a></p>
      Replyupvote ()
      Reply
        View History
        GrovePi+
        SKU 103010002
        $29.99
        11 Available
        ADD TO CART
        $29.99/1pcs+
        $26.99/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
