Product Details
Wiki & Learn
Reviews
Download PDF
Feature
News: 【Ends on Dec 31 , 2026(GMT+8)|Applicable to all warehouses】
  • Unparalleled Range and Coverage: Engineered with a high-performance, oversized antenna, the ZWA-2 pushes signal through thick walls and across long distances, eliminating dead spots where other controllers fail.
  • Rock-Solid Network Stability: By operating on the dedicated Z-Wave® frequency, the ZWA-2 avoids the congested 2.4GHz band, shielding your smart home from Wi-Fi and Bluetooth interference for flawless, reliable communication.
  • Future-Proof and Globally Compatible: Ready for any setup, the ZWA-2 supports both traditional Z-Wave® mesh and the groundbreaking Z-Wave® Long Range protocol. With automatic region configuration when used with the Z-Wave® JS add-on, it's the single, definitive controller for users anywhere in the world.
  • Optimized for Efficiency: The ZWA-2's superior sensitivity means your battery-powered devices don't have to shout. They communicate less often and at lower power, dramatically improving their battery life and contributing to overall network health.
  • Intelligent Orientation Sensing: A built-in tilt sensor ensures you've installed the device in the optimal vertical position for peak performance, indicated by a blinking yellow LED. For custom installations, this indicator can be easily disabled within Home Assistant.
  • Customizable Status LED: Tailor the device to your space. The active status LED's color can be fully customized or turned off completely through the Home Assistant interface.
Note:
  • Connect ZWA-2 was designed to operate with Home Assistant and the Z-Wave JS add-on. If you use Connect ZWA-2 without Home Assistant, please visit here.
  • Currently, Z-Wave Long Range only supports the North American and European regions, with limited device availability in Europe.
Parameter
Product
Model No.
NC-ZWA-9734
Conformity
CE, FCC, RCM
FCC-ID
2A8ZE05
Origin
Made in China
Product Details
SoCs
Silicon Labs ZG23 (Z-Wave®)
ESP32-S3 (USB-serial bridge)
Power and Data
USB-C
5VDC/1A
Supported Protocols
Z-Wave®, Z-Wave® Long Range
Z-Wave® Series
800
Antenna Characteristics
Frequency Range
860-930 MHz
Peak Gain
3.38 dBi
Radiation Pattern
Omnidirectional
Device Characteristics
Dimensions & Weight
Device: 125x125x315 mm, 350 g
In box: 345x222x45 mm, 600 g
Material
Enclosure:
  • Polycarbonate plastic
  • Color: White and semi-transparent
Operating Conditions
Indoor use only0 °C to 65 °C (32 °F to 149 °F)
Humidity: non-condensing
Keep in dry, not excessively dusty environment, as this can cause damage to the unit
Do not leave the unit in direct sunlight or near any heat source, as this can cause overheating.
Application
  • To serve as the central Z-Wave® controller within a Home Assistant smart home system.
  • Enable the integration, automation, and management of a wide array of Z-Wave® end devices (e.g., sensors, lights, switches, locks, thermostats) through the Home Assistant platform.
Certification
HSCODE8517629990
USHSCODE8517620020
UPC
EUHSCODE8517180000
COOCHINA
Home Assistant Connect ZWA-2 (Base + Antenna)
x1
USB-C to USB-A cable
x1
SKU 110992144
The most performant Z-Wave adapter available, it is the ultimate way to connect any Z-Wave device to Home Assistant. The antenna and base are precisely tuned to Z-Wave’s ideal wavelength, working in harmony to provide a reliable connection and maximize range. With support for Z-Wave Long Range*, it provides a more dependable, responsive connection to far-away devices and improved battery life. Designed by the team driving forward Home Assistant and Z-Wave JS, it offers plug-and-play setup and effortless migrations.
USD$69.00
