seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Intel® Edison Kit for Arduino
      SKU 102990162
      $85.95$97.95
      18 Available
      ADD TO CART
      This kit includes an Arduino Breakout, which essentially gives your Edison the ability to interface with Arduino shields or any board with the Arduino footprint.
      Dimensions:127mm x 72mm x 12mm
      The Intel Edison module is included.
      • Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32-bit Intel® Quark™ microcontroller at 100 MHz.  It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp.
      • The Intel Edison module will initially support development with Arduino* and C/C++, followed by Node.JS, Python, RTOS, and Visual Programming support in the near future.
      • It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service.
      • Has an SD card connector, micro USB or standard sized USB host Type-A connector(via mechanical switch), Micro USB device, 6 analog inputs, and 20 ditial input/output pins, 1x UART, 1x I2C, and 1x ICSP 6-pin header (SPI) Power jack with 7V-15V DC input.
      • Intel® Edison Module
      • Intel® Edison with Kit for Arduino
      Physica
      Form factorBoard with 70-pin connector
      Dimensions127.0 x 72.0 x 12.0 mm
      Operating temperature0 to 40 degC
      ConnectorHirose DF40 Series (1.5mm, 2.0mm, or  3.0mm stack height)
      Memory
      Max Memory size4GB
      Memory typeDDR3, Nand Flash
      Physical add. Ext.32-bit
      # of  DIMMs0
      ECC Memory supported:NO
      External Interfaces
      Total of 40 GPIOs which can be configured as:
      SD Card1 Interface
      UART2 Controllers
      I2C2 Controllers
      SPI1 Controller with 2 chip selects
      I2S1 Controller
      GPIOAdditional 12 (with 4 capable of PWM)
      USB 2.01 OTG Controller
      Clock Output32 KHz, 19.2 MHz
      Major Edison Components
      SoC22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz
      RAM1 GB LPDDR3 POP memory
      Flash Storage4 GB eMMC
      WiFiBroadcom 43340 802.11 a/b/g/n
      Dual-band (2.4 and 5 GHz)
      On board antenna or external antenna SKU configurations
      BluetoothBT 4.0
      Power
      Input3.3V - 4.5V
      Output100ma @3.3V and 100ma @ 1.8V
      PowerStandby (No radios): 13mW
      Standby (BT 4.0): 21.5mW
      Standby (WiFi): 35 mW
      Firmware + Software
      CPU OSYocto Linux v1.6
      Development EnvironmentsArduino IDE
      Eclipse supporting: C, C++, Python
      Intel XDK supporting: Node.JS, HTML5
      MCU OSRTOS
      Development EnvironmentsMCU SDK and IDE
      Documents
      Related Products
      Technical Details
      WeightG.W 152g
      BatteryExclude
      Intel® Edison Module1
      Intel® Edison with Kit for Arduino1
      Reviews
      Questions and Answers
      SUBMIT
      0
      0
      Does this actually include an edison board?
      on Oct 19,2016
      Replyupvote ()
      <p>Yes, Intel Edison for Arduino includes an edison board and Arduino breakout board.</p>
      on Oct 20,2016 10:49 AM
      Replyupvote ()
      Reply
        View History
        SKU 102990162
        $85.95$97.95
        18 Available
        ADD TO CART
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
