seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Mini 125Khz RFID Module - Pre-Soldered Antenna (35mm Reading Distance)
      SKU 113990042
      $9.90
      30 Available
      $9.90/1pcs+
      $8.91/10pcs+
      $8.41/20pcs+
      $7.92/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This RFID module is designed for reading code from 125Khz card compatible read-only tags and read/write card. It will notify whenever 125Khz tag approaches, the tag serial number will be send via TX pin or Wiegand pin. Super small size design, it is widely applied in office/home security, personal identification, access control, anti-forgery, interactive toy and production control systems etc.
      • Small Outline Design
      • Pre-Soldered Mini Antenna
      • UART TTL Interface
      • Maximum Effective Distance Up To 35mm
      • Support EM4100 Compatible Read Only or Read/Write Tags
      • Working Frequency: 125Khz
      • Baud Rate: 9600
      • Interface: TTL or Wiegand26
      • Working Voltage: DC 3.3V - 5V
      • Working Current: 19mA - 25mA
      • Reading Distance: Max.35mm
      • Working Temperature: -10℃ to +70℃
      • Storage Temperature: -20℃ to +80℃
      • Humidity: 0% - 95%
      • Antenna Diameter: 15mm
      • Antenna Inductance: 388uH
      • PCBA Dimension: 18 x 13 x 3.7mm
      Software
      Technical Details
      Dimensions60mm x 60mm x 10mm
      WeightG.W 3.5g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hello, how many multiple readers can i handle with an arduino uno? is it possible to use this reader (multiple readers) with a Raspberry PI? thank
      on Mar 21,2017
      Replyupvote ()
      Hi Dear Customer, this reader uses the serial port. we suggest the software serial to readers, and hardware serial port for the PC display. So you can connect multiple readers. Bill
      on Dec 12,2017 11:05 AM
      Replyupvote ()
      Reply
      0
      Hello,can anyone tell me:1. Which IC is mounted on the module?2. What's the pinout of the module? I guess V is 3,3-5V, G is GND, RX and TX belong to the UART. But what about RST and S?3. How to interface with the module? I can't read anything from the UART when bringing a RFID-Tag into the range of the reader.Thanks
      on Apr 03,2018
      Replyupvote ()
      I did a little reverse engineering by myself, so:1. There's no special RFID-IC on the module. It's a Microcontroller from ST: STM8S003F32. The RST-Pin is the RESET of the Microcontroller. I still don't know what the S-Pin is for..3. Now I can read from the UART. The supply voltage was too low.. My fault. But why is it reading just four numbers instead of five? I know that there are five numbers stored on my RFID-Tags.
      on Apr 05,2018 15:57 PM
      Replyupvote ()
      Reply
      0
      I noticed in the library that there is a buzzer output from the chip that is not broken out. Could you provide the datasheet so that I could look into adding that buzzer? Thank you.
      on Mar 06,2018
      Replyupvote ()
      Hi tom~You can see pin map in the page below. Regards=================================dividing line==============================https://github.com/Seeed-Studio/RFID_Library/blob/master/README.md
      on Mar 12,2018 15:31 PM
      Replyupvote ()
      Reply
      0
      Does it have FCC certification or its possible to get one?
      on Apr 03,2018
      Replyupvote ()
        View History
        SKU 113990042
        $9.90
        30 Available
        Maximum Qty: 5
        $9.90/1pcs+
        $8.91/10pcs+
        $8.41/20pcs+
        $7.92/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
