the AI Hardware Partner
Toggle Nav
Loading...
Optor Cam2pc Visual-Inertial SLAM
Rating:
100 % of 100
Loitor Visual Inertial Camera is a general vision sensor designed for visual algorithm developers
$149.00
Out of stock
  • 10+: $134.10
Optor Visual Inertial Camera is a general vision sensor designed for visual algorithm developers.Providing abundant hardware control interface and data interface aimed to reduce development threshold with reliable image and inertial data.
Hardware Specifications
  • Physical Dimensions
  • Camera Coordinate System between Left camera and IMU
  • Hardware Performance and Specifications
CMOS
IMU
Type
MT9V034
MPV-6050
Exposure Mode
Global shutter
Controller IC
CY68013
STM-32
FPS
24-65fps
200fps
Supported Resolution
320*240/640*480/752*480
Firmware Update
Firmware Update Supported By Windows Software
Baseline
10cm
Lens physical interface
M12 Lens interface
Lens Specifications
2.1mm/150º+6mm/60º
Data interface
Usb 2.0
Data Delay
(1/Current_FPS)s
100us
Frame Synchronization
Stereo Synchronization Triggered By Camera Driver
Product Feature
  • IMU zero bias calibration program, Zero bias initialization algorithm of DMP, High precision 6-DOF data, Minimum attitude drift.
  • Stereo optical parameters already accurately calibrated
  • The lens seat rifled through special processing, to ensure the camera would not loosen in the long-term delivery and the lens can be replaced.
  • SDK needs no compilation,no special dependency libraries(only relay on libusb)
  • stable and reliable ROS driver
  • Ubuntu 16/14 supported
Dimensions 0mm x0mm x0mm
Weight G.W 140g
Battery Exclude
Camera Module 1
usb cable 1
HSCODE 9031809090
USHSCODE 9026104000
EUHSCODE 9013101000
COO CHINA
RoHS 1
Documentations
Documents
  1. Product Quality
    100%
    By
1 Item
Show per page
