Imagine 5 networks in one perfectly-formed, same-small-foot-print-as WiPy and LoPy, IoT development board. MicroPython enabled. FiPy includes WiFi, Bluetooth, LoRa, Sigfox and dual LTE-M (CAT M1 and NBIoT) the FiPy gives access to all the world’s LPWAN networks on one tiny board.
Get on with a board that gives you full flexibility during testing, install, deployment and even later when you want to switch real-time your airtime network provider. You can switch when the time is right for you or set some parameters that will do so automatically.
FiPy Features
Powerful CPu
Five networks: WiFi, BLE, cellular LTE-CAT M1/NB1, LoRa and Sigfox
1KM WiFi range
MicroPython enabled
Fits in a standard breadboard (with headers)
Ultra-low power usage: a fraction compared to other connected microcontrollers
| Dimensions | 0mm x0mm x0mm |
| Weight | G.W 31g |
| Battery | Exclude |
| Espressif ESP32 SoC | |
| Dual processor and WiFi radio system on chip | |
| Networking processor handles the WiFi connectivity and the IPv6 stack | |
| Main processor is entirely free to run the user application | |
| An extra ULP-coprocessor that can monitor GPIOs, the ADC channels and control most of the internal peripherals during deep-sleep mode while only consuming 25uA | |
| 2 x UART, 2 x SPI, I2C, micro SD card | |
| ANalog channels: 8×12 bit ADCs, 2×8 bit DAC | |
| Timers: 2×64 bit with PWM with up to 16 channels | |
| DMA on all peripherals | |
| GPIO: Up to 22 | |
| SHA, MD5, DES, AES | |
| 802.11b/b/n 16mbps | |
| Low energy and classic RTC | |
| Running at 32KHz | |
| Node range: Up to 50km | |
| SSL/TLS support up to 1.2 | |
| WPA Enterprise security | |
| AES encryption engine | |
| RAM: 4MB | |
| Flash Memory: 8MB | |
| GPIO: Up to 22 | |
| Hardware floating point acceleration | |
| Python multi-threading | |
| Voltage Input: 3.3V – 5.5V | |
| 3v3 output capable of sourcing up to 400mA |
| FiPy | 1 |
