Raspberry Pi 0.96” OLED Display Module
$24.50
In stock
70+ Available
Qty Discount available
  • $22.05 /10pcs+
Raspberry Pi 0.96’ OLED display module is made by 128x64 yellow and blue OLED pixels , diagonal is only 0.96 inch . The controller is SSD1306, communicates via 4-wire SPI, the display have its own backlight, no backlight LED is required ,This reduces the power required to run the OLED and is why the display has such high contrast , extremely wide viewing angle and extremely operating temperature
Product Overview:
Features:
  • Ultra low power supply
  • Maximum current 100uA
  • Keep up current 12.25uA
  • Hardware keep up display
  • 3.3V work voltage ,([MIN 1.6V] ,[MAX:3.6V])
  • Internal DC/DC voltage converter
  • SPI driver support , AT 64MHz[TYP] 125MHZ[OB]
  • FP frequency: 64fps[TYP] 368fps[OB]
  • Compatible with Raspberry Pi A+,B,B+/2.
Specification:
  • Outline Drawing: 370x300(mm)
  • Number of pixels: 128x64
  • Panel size:26.70x19.26x1.45(mm)
  • Active area: 21.74x10.864(mm)
  • Pixel pitch 0.17x0.17(mm)
  • Pixel size: 0.154x0.154(mm)
Hardware conection:
Document
Raspberry Pi 0.96’ OLED Display Module User Manual
Dimensions 105mm x80mm x20mm
Weight G.W 21g
Battery Exclude
HSCODE 8517703000
ROHS 1
Product Faqs
Sort by
Tags:
