the AI Hardware Partner
Toggle Nav
Loading...
Transparent ABS Enclosure with Cooling Fan for Raspberry Pi 3 Model B & 3B+
Rating:
100 % of 100
Raspberry Pi ABS Enclosure with Cooling Fan, it can protect your Raspberry Pi and cool it down at the same time. It is made of high quality ABS, which has high impact resistance and high toughness characteristics. Meanwhile, this enclosure can drive away heat with a built-in fan
$2.95
Out of stock
  • 10+: $2.80
Now, the Raspberry Pi is a superstar in open source hardware, more and more people use the Raspberry Pi. However, it is quite often that the Raspberry Pi is damaged by an accidental fall or running slow because of high temperatures. So why not choose some gears for your Raspberry Pi to make it stronger and faster.
Here, we recommend the Raspberry Pi ABS Enclosure with Cooling Fan, it can protect your Raspberry Pi and cool it down at the same time. It is made of high-quality ABS, which has high impact resistance and high toughness characteristics. Meanwhile, this enclosure can drive away heat with a built-in fan.
We also provide a black version, you can check here.
Assembly drawing
Dimensions 93.5mm x62.7mm x27.5mm
Weight G.W 40g
Battery Exclude
Fan Operating Voltage 5V
Max Fan current 0.15A
Max Fan Power 0.75W
Supported Models Raspberry Pi 1 Model B+/ 2 Model B / 3 Model B / 3 Model B+
Raspberry Pi ABS Enclosure with Cooling Fan - Transparent 1
Cooling Fan 1
Gasket 4
Screw 2
HSCODE 8414599060
USHSCODE 8414519090
EUHSCODE 8414591500
COO CHINA
RoHS 1
  1. Product Quality
    100%
    Documentation
    100%
    from order view
    Enclosure is well made of durable plastic, all elements fit well together
    By
1 Item
Show per page
