Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Explore the full reSpeaker lineup. Compare specs, find your ideal fit, and catch the latest updates & community news. Check the reSpeaker Series Landing Page
Note:
  • The reSpeaker XVF3800 with no XIAO versions (101991441, 114993701) come with factory-installed USB audio firmware.
  • The reSpeaker XVF3800 with XIAO ESP32S3 versions (114993700, 114993702) come with factory-installed I2S firmware for MCU integration.
  • All 4 versions support DFU mode for users to switch the firmware.
Professional AI Voice Capture Powered by XMOS XVF3800
A 4-mic array for clear voice input. Built for your next AI project. Powered by AEC, beamforming, de-reverberation, DoA, noise suppression, and 60dB AGC for clear and reliable voice capture.
Feature 1: Hear You Clearly from Across the Room
Four microphones. Up to 5 m pickup. Precise Direction of Arrival (DoA) detection, with XMOS processing that prepares clearer audio for your application.
5m
Far-field Voice Capture
Capture clear voice from up to 5 meters away, enabling reliable interaction in smart homes, robots, and conference environments.
360°
Voice Direction Detection
A circular 4-microphone array detects voice direction accurately from any angle with advanced DoA technology.
Feature 2: Clear Voice Input Needs Professional Audio Processing
Struggling with these voice interaction challenges?
- Voice recognition becomes unreliable in noisy environments?
- Audio playback causes echo and disrupts voice interaction?
- Voice input levels vary when users speak from longer or different distances?
reSpeaker XVF3800 is designed to solve these challenges with professional-grade voice front-end processing.
AEC
Acoustic Echo Cancellation
Eliminate echo during simultaneous playback and recording
Removes acoustic echo caused by speaker playback being captured by the microphone array, enabling natural full-duplex interaction for voice assistants, conferencing devices, and robots.
AGC
Automatic Gain Control
Maintain consistent voice levels across distances
Automatically adjusts input gain to keep voice output stable, improving downstream ASR performance when users speak at different distances and volumes.
NS
Noise Suppression
Enhance voice clarity in noisy environments
Suppresses unwanted background noise such as fan noise, keyboard typing, and ambient chatter, improving signal-to-noise ratio for smarter voice applications.
Developer-Friendly
Feature 3: Built for Easy Integration
With plug-and-play setup, a compact form factor for embedded scenarios, and flexible audio connectivity, reSpeaker XVF3800 enables developers to move from prototype to deployment with minimal complexity.
01 / USB
Plug-and-Play USB
Connect to compatible PCs and single-board computers, including Raspberry Pi and NVIDIA Jetson.
02 / I²S
Built for MCU integration
Use I²S to connect with supported platforms such as XIAO and Arduino.
03 / COMPACT DESIGN
Easy to embed
The flat design fits space-constrained builds. Keep the microphone inlet—the side marked with the Seeed Studio logo—facing the sound source.
04 / AUDIO
Flexible audio output
Connect compatible external audio devices through the 3.5 mm jack. Speaker not included.
Firmware and setup requirements vary by host and operating mode.
The microphone inlet is on the back of the device, beside the Seeed Studio logo. When positioning the device, make sure the inlet faces the sound source.
Feature 4: Seamless Integration for Deployment
reSpeaker XVF3800 is a go-to choice for fast building solutions that enable seamless hardware and software integration across diverse application scenarios.
With XIAO ecosystem compatibility, robotics adaptability, and streamlined Voice Agent enablement, it reduces integration complexity and shortens time-to-market.
Core Chip
XMOS XVF3800
MCU
XIAO ESP32S3 (Pre-soldered)
Digital Microphones
High-performance digital microphones * 4
Sensitivity
-26 dBFS
Acoustic Overload Point
120 dBL
SNR
64 dBA
Power Supply
USB 5V, external 5V
Dimensions
102mm x 102mm x 10mm
Audio Output
Speaker Connector / 3.5mm Headphone jack
Maximum Sampling Rate
16Khz
Speaker
Supports 5W amplifier speakers.
Wireless
WiFi 802.11 b/g/n, Bluetooth 5.0 LE
ESP32S3 Features
Dual-core 240MHz, 8MB Flash, 8MB PSRAM
Choose Your reSpeaker
reSpeaker Flex
reSpeaker XVF3800
reSpeaker Lite
reSpeaker Pi HAT
Product
Mic Array Type
Circular/Linear
Circular
Linear
Linear
Mic Spacing
Circular: 44mm
Linear: 33mm
66mm
70mm
No. of Mics
4 PDM MEMS Microphones
2 PDM MEMS Microphones
2 Analog Microphones
Chip
XMOS XVF3800
XMOS XVF3800
XMOS XU316
TLV320AIC3104 Audio Codec
Pickup Distance
Up to 5m
Up to 5m
Up to 3m
Up to 3m
Voice Capture
Circular: 360°
Linear: 180°
360°
180°
AI Algorithms
AEC
Noise Suppression
VNR
AGC
DoA
De-Reverberation
Multi-beamforming
AEC
Noise Suppression
VNR
AGC
DoA
De-Reverberation
Multi-beamforming
IC
EC
AEC
Noise Suppression
VNR
AGC
VAD
VAD
DoA
Speaker
10w
5w
5w
Connectivity
USB, I2S
USB, I2S
USB, I2S
I2S
LED
1 Power LED (green, solid on)
12 Programmable RGB LED
1 Programmable RGB LED
3 Programmable RGB LEDs
Compatibility
XIAO ESP32S3
Raspberry Pi
Jetson
PC
any platform supports I2S and USB Audio
XIAO ESP32S3
Raspberry Pi
Jetson
PC
Raspberry Pi
Jetson
PC
Raspberry Pi 5
Raspberry Pi Zero
Raspberry Pi 1B+/2B/3B/3B+/4B
Applications
Robotics Integration
Digital Signage
Educational Terminal
Embedded Application
Smart Home Voice Control
Physical AI Voice Agent
Smart Voice Assistants
Smart Conference
Wireless Voice Asistants
Home Assistant Integration
DIY projects
Prototyping
Education
Raspberry Pi Compatible
Hardware Overview
Hardware Overview
Pin_Map
Dimension
Application
Smart Home Voice Control Using reSpeaker XVF3800 Microphone Array
The reSpeaker XVF3800 4-mic array with XIAO ESP32S3 can be seamlessly integrated into Home Assistant voice systems, serving as dedicated Home Assistant voice hardware for localized control and smart home automation.
Robotics Integration with reSpeaker XVF3800 for Embedded Applications
The compact design supports smooth integration into robotic platforms, with support for ROS2 to streamline system-level communication and development. 4-mic array enables 360° voice localization, voice command recognition, and noise suppression for interactive robotics, smart toys, and voice-controlled machines. Ideal choice for reliable voice interaction and human-machine communication across service, education, and industrial robotics applications.
Build Physical AI Voice Agent with reSpeaker XVF3800
Through SDK and platform compatibility, reSpeaker XVF3800 supports rapid integration with voice AI frameworks and cloud-based services, allowing devices to be quickly transformed into scalable voice agent solutions.
2. Running Agora Conversational AI on reSpeaker XVF3800
Use reSpeaker XVF3800 with XIAO ESP32S3 as an edge voice AI device to establish a stable, low-latency, bidirectional audio link via Agora RTC, and directly call Agora Conversational AI Agent API v2 on the device to complete the conversational loop of ASR → LLM → TTS: the microphone array captures audio and sends it uplink; the cloud AI generates spoken replies and sends them downlink—delivering a “phone-call-like” voice conversation experience.
View more AI agent projects
3. On-Edge AI Voice Agent Using reSpeaker XVF3800 and Jetson AGX Orin
After the microphone array detects a custom wake word, reSpeaker captures a 5-second voice query and uses a local STT engine. A local Llama 3 model then processes the query, enhanced by a RAG architecture for accurate knowledge retrieval and reasoning. The final answer is generated through a local TTS engine. The solution supports deployment across multiple local environments, including NVIDIA Jetson, Raspberry Pi, x86 servers, and Linux / Windows systems.
4. Build Xiaozhi AI Voice Assistant with reSpeaker XVF3800
Using reSpeaker XVF3800 to build a compact, cloud-connected Xiaozhi voice assistant powered by large language models. With professional far-field audio capture and robust noise suppression, it transforms lightweight edge hardware into a scalable Voice Assistant.
5. Bulid You Own OpeClaw Voice AI Agent with reSpeaker XVF3800
With reSpeaker's powerful audio capture, combined with OpenClaw's flexible AI agent framework, you can easily create a voice-controlled smart assistant that can automatically understand and respond to your commands. (e.g. locate Lark groups and send interactive meeting invitation cards/Voice-based summarization and automated email delivery)
6. Build Your AI Assistant Voice Interface with MimiClaw & reSpeaker XVF3800
MimicLaw is a lightweight implementation inspired by OpenClaw. It explores how similar agent logic can run in extremely resource-constrained environments. By using reSpeaker XVF3800 as the voice interface, we can turn MimicLaw into something more tangible: a physical AI companion that lives on your desk and interacts naturally through voice.
Build Smart Voice Assistants Using reSpeaker XVF3800
Seamlessly integrates with Amazon Alexa, Google Assistant, Home Assistant, and other mainstream voice AI platforms for far-field voice control, smart home automation, and interactive voice applications.
Smart Conference Solutions Using reSpeaker XVF3800
Compatible with Microsoft Teams, Zoom, and other popular conferencing software via USB. 4-mic array supports beamforming and DoA detection to deliver clear multi-person audio pickup and real-time status feedback.
Smart Meeting Solutions Using reSpeaker and reRouter
reSpeaker 4-mic array transforms meetings into structured, actionable insights. Designed for conference rooms, reSpeaker can clearly capture voices from a distance(up to 5 meters), handle multiple speakers, and continuously record discussions. By running local recording, STT, and AI-powered summarization, the entire process happens on-device. This ensures privacy, reduces deployment complexity, and makes it ideal for long-term use in offices, meeting rooms, and interview spaces.
Certification
HSCODE8518900090
USHSCODE8518902000
UPC841454120278
EUHSCODE8517180000
COOCHINA
reSpeaker Mic Array v3.0
x1
reSpeaker XMOS XVF3000 - AI-powered 4-Mic Array
SKU 107990053
Upgrade Version: [reSpeaker XVF3800] with improved far-field voice capture and advanced audio processing at a LOWER price!
This circular 4-mic array is a professional solution for adding voice interaction to projects. Powered by XMOS XVF3000 with built-in AI sound processing algorithms, it clearly picks up voices from any direction up to 5 meters away. Features 360° far-field voice pickup (up to 5m), AEC, AGC, DoA, beamforming, and noise suppression.
Mic Array Numbers
Voice Processor
XIAO ESP32-S3
Case
USD$64.00
