Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Explore the full reSpeaker lineup. Compare specs, find your ideal fit, and catch the latest updates & community news. Check the reSpeaker Series Landing Page
Note:
  • The reSpeaker XVF3800 with no XIAO versions (101991441, 114993701) come with factory-installed USB audio firmware.
  • The reSpeaker XVF3800 with XIAO ESP32S3 versions (114993700, 114993702) come with factory-installed I2S firmware for MCU integration.
  • All 4 versions support DFU mode for users to switch the firmware.
Professional AI Voice Capture Powered by XMOS XVF3800
A 4-mic array for clear voice input. Built for your next AI project. Powered by AEC, beamforming, de-reverberation, DoA, noise suppression, and 60dB AGC for clear and reliable voice capture.
Feature 1: Hear You Clearly from Across the Room
Four microphones. Up to 5 m pickup. Precise Direction of Arrival (DoA) detection, with XMOS processing that prepares clearer audio for your application.
5m
Far-field Voice Capture
Capture clear voice from up to 5 meters away, enabling reliable interaction in smart homes, robots, and conference environments.
360°
Voice Direction Detection
A circular 4-microphone array detects voice direction accurately from any angle with advanced DoA technology.
Feature 2: Clear Voice Input Needs Professional Audio Processing
Struggling with these voice interaction challenges?
- Voice recognition becomes unreliable in noisy environments?
- Audio playback causes echo and disrupts voice interaction?
- Voice input levels vary when users speak from longer or different distances?
reSpeaker XVF3800 is designed to solve these challenges with professional-grade voice front-end processing.
AEC
Acoustic Echo Cancellation
Eliminate echo during simultaneous playback and recording
Removes acoustic echo caused by speaker playback being captured by the microphone array, enabling natural full-duplex interaction for voice assistants, conferencing devices, and robots.
AGC
Automatic Gain Control
Maintain consistent voice levels across distances
Automatically adjusts input gain to keep voice output stable, improving downstream ASR performance when users speak at different distances and volumes.
NS
Noise Suppression
Enhance voice clarity in noisy environments
Suppresses unwanted background noise such as fan noise, keyboard typing, and ambient chatter, improving signal-to-noise ratio for smarter voice applications.
Developer-Friendly
Feature 3: Built for Easy Integration
With plug-and-play setup, a compact form factor for embedded scenarios, and flexible audio connectivity, reSpeaker XVF3800 enables developers to move from prototype to deployment with minimal complexity.
01 / USB
Plug-and-Play USB
Connect to compatible PCs and single-board computers, including Raspberry Pi and NVIDIA Jetson.
02 / I²S
Built for MCU integration
Use I²S to connect with supported platforms such as XIAO and Arduino.
03 / COMPACT DESIGN
Easy to embed
The flat design fits space-constrained builds. Keep the microphone inlet—the side marked with the Seeed Studio logo—facing the sound source.
04 / AUDIO
Flexible audio output
Connect compatible external audio devices through the 3.5 mm jack. Speaker not included.
Firmware and setup requirements vary by host and operating mode.
The microphone inlet is on the back of the device, beside the Seeed Studio logo. When positioning the device, make sure the inlet faces the sound source.
Feature 4: Seamless Integration for Deployment
reSpeaker XVF3800 is a go-to choice for fast building solutions that enable seamless hardware and software integration across diverse application scenarios.
With XIAO ecosystem compatibility, robotics adaptability, and streamlined Voice Agent enablement, it reduces integration complexity and shortens time-to-market.
Core Chip
XMOS XVF3800
Digital Microphones
High-performance digital microphones * 4
Sensitivity
-26 dBFS
Acoustic Overload Point
120 dBL
SNR
64 dBA
Power Supply
USB 5V, external 5V
Dimensions
108mm x 108mm x 18mm
Audio Output
Speaker Connector / 3.5mm Headphone jack
Maximum Sampling Rate
16Khz
Speaker
Supports 5W amplifier speakers.
Choose Your reSpeaker
reSpeaker Flex
reSpeaker XVF3800
reSpeaker Lite
reSpeaker Pi HAT
Product
Mic Array Type
Circular/Linear
Circular
Linear
Linear
Mic Spacing
Circular: 44mm
Linear: 33mm
66mm
70mm
No. of Mics
4 PDM MEMS Microphones
2 PDM MEMS Microphones
2 Analog Microphones
Chip
XMOS XVF3800
XMOS XVF3800
XMOS XU316
TLV320AIC3104 Audio Codec
Pickup Distance
Up to 5m
Up to 5m
Up to 3m
Up to 3m
Voice Capture
Circular: 360°
Linear: 180°
360°
180°
AI Algorithms
AEC
Noise Suppression
VNR
AGC
DoA
De-Reverberation
Multi-beamforming
AEC
Noise Suppression
VNR
AGC
DoA
De-Reverberation
Multi-beamforming
IC
EC
AEC
Noise Suppression
VNR
AGC
VAD
VAD
DoA
Speaker
10w
5w
5w
Connectivity
USB, I2S
USB, I2S
USB, I2S
I2S
LED
1 Power LED (green, solid on)
12 Programmable RGB LED
1 Programmable RGB LED
3 Programmable RGB LEDs
Compatibility
XIAO ESP32S3
Raspberry Pi
Jetson
PC
any platform supports I2S and USB Audio
XIAO ESP32S3
Raspberry Pi
Jetson
PC
Raspberry Pi
Jetson
PC
Raspberry Pi 5
Raspberry Pi Zero
Raspberry Pi 1B+/2B/3B/3B+/4B
Applications
Robotics Integration
Digital Signage
Educational Terminal
Embedded Application
Smart Home Voice Control
Physical AI Voice Agent
Smart Voice Assistants
Smart Conference
Wireless Voice Asistants
Home Assistant Integration
DIY projects
Prototyping
Education
Raspberry Pi Compatible
Hardware Overview
Application
Smart Home Voice Control Using reSpeaker XVF3800 Microphone Array
The reSpeaker XVF3800 4-mic array with XIAO ESP32S3 can be seamlessly integrated into Home Assistant voice systems, serving as dedicated Home Assistant voice hardware for localized control and smart home automation.
Robotics Integration with reSpeaker XVF3800 for Embedded Applications
The compact design supports smooth integration into robotic platforms, with support for ROS2 to streamline system-level communication and development. 4-mic array enables 360° voice localization, voice command recognition, and noise suppression for interactive robotics, smart toys, and voice-controlled machines. Ideal choice for reliable voice interaction and human-machine communication across service, education, and industrial robotics applications.
Build Physical AI Voice Agent with reSpeaker XVF3800
Through SDK and platform compatibility, reSpeaker XVF3800 supports rapid integration with voice AI frameworks and cloud-based services, allowing devices to be quickly transformed into scalable voice agent solutions.
2. Running Agora Conversational AI on reSpeaker XVF3800
Use reSpeaker XVF3800 with XIAO ESP32S3 as an edge voice AI device to establish a stable, low-latency, bidirectional audio link via Agora RTC, and directly call Agora Conversational AI Agent API v2 on the device to complete the conversational loop of ASR → LLM → TTS: the microphone array captures audio and sends it uplink; the cloud AI generates spoken replies and sends them downlink—delivering a “phone-call-like” voice conversation experience.
View more AI agent projects
3. On-Edge AI Voice Agent Using reSpeaker XVF3800 and Jetson AGX Orin
After the microphone array detects a custom wake word, reSpeaker captures a 5-second voice query and uses a local STT engine. A local Llama 3 model then processes the query, enhanced by a RAG architecture for accurate knowledge retrieval and reasoning. The final answer is generated through a local TTS engine. The solution supports deployment across multiple local environments, including NVIDIA Jetson, Raspberry Pi, x86 servers, and Linux / Windows systems.
4. Build Xiaozhi AI Voice Assistant with reSpeaker XVF3800
Using reSpeaker XVF3800 to build a compact, cloud-connected Xiaozhi voice assistant powered by large language models. With professional far-field audio capture and robust noise suppression, it transforms lightweight edge hardware into a scalable Voice Assistant.
5. Bulid You Own OpeClaw Voice AI Agent with reSpeaker XVF3800
With reSpeaker's powerful audio capture, combined with OpenClaw's flexible AI agent framework, you can easily create a voice-controlled smart assistant that can automatically understand and respond to your commands. (e.g. locate Lark groups and send interactive meeting invitation cards/Voice-based summarization and automated email delivery)
6. Build Your AI Assistant Voice Interface with MimiClaw & reSpeaker XVF3800
MimicLaw is a lightweight implementation inspired by OpenClaw. It explores how similar agent logic can run in extremely resource-constrained environments. By using reSpeaker XVF3800 as the voice interface, we can turn MimicLaw into something more tangible: a physical AI companion that lives on your desk and interacts naturally through voice.
Build Smart Voice Assistants Using reSpeaker XVF3800
Seamlessly integrates with Amazon Alexa, Google Assistant, Home Assistant, and other mainstream voice AI platforms for far-field voice control, smart home automation, and interactive voice applications.
Smart Conference Solutions Using reSpeaker XVF3800
Compatible with Microsoft Teams, Zoom, and other popular conferencing software via USB. 4-mic array supports beamforming and DoA detection to deliver clear multi-person audio pickup and real-time status feedback.
Smart Meeting Solutions Using reSpeaker and reRouter
reSpeaker 4-mic array transforms meetings into structured, actionable insights. Designed for conference rooms, reSpeaker can clearly capture voices from a distance(up to 5 meters), handle multiple speakers, and continuously record discussions. By running local recording, STT, and AI-powered summarization, the entire process happens on-device. This ensures privacy, reduces deployment complexity, and makes it ideal for long-term use in offices, meeting rooms, and interview spaces.
Certification
HSCODE8518900000
USHSCODE8518902000
UPC
EUHSCODE8517180000
COOCHINA
reSpeaker XVF3800 – USB 4-Mic Array
x1
When selecting a microphone array, consider: - Voice pickup requirements (e.g., far-field pickup distance, pickup direction) - Space limitations - Requirements for audio processing algorithms (e.g., noise suppression, AEC, AGC) - Compatibility with your platform (e.g., Raspberry Pi, ESPHome) reSpeaker provides a balanced solution across these aspects for many AIoT and voice AI use cases.
Yes. reSpeaker is well-suited for robotics and embodied AI applications, where voice serves as a key interaction interface. The reSpeaker microphone array series is available in various sizes and form factors, with customization options to meet the space constraints of different embedded projects. Its onboard acoustic algorithms, including advanced noise suppression, help address common challenges in robotics, such as interference from internal motors and servo noise. In particular, the reSpeaker Flex is designed specifically for robotics and embedded AI use cases. By separating the core board from the microphone array, and providing both linear and circular arrays, it provides greater flexibility for integration in space-constrained designs.
reSpeaker XVF3800 stands out with advanced built-in acoustic algorithms powered by XMOS, offering high-quality voice capture and reliable performance espacially regarding noise suppression. It is designed for demanding voice AI applications such as real-time interaction and embedded systems.
Yes. Depending on the setup, reSpeaker can be used with local voice processing pipelines, including offline wake word detection and edge AI workflows. This helps ensure low latency and better privacy compared to cloud-only solutions.
Yes. reSpeaker (XVF3800 / Lite) devices are well-suited for voice assistant projects and are compatible with popular platforms such as Home Assistant and ESPHome. With support for XIAO ESP32S3, they can be seamlessly integrated into ESPHome-based workflows and smart home ecosystems. For applications where wake word detection, speech-to-text, and voice control are important, reSpeaker provides far-field voice pickup, noise suppression, and high-quality audio input for more reliable performance. It also supports Linux-based systems, Raspberry Pi, Jetson, and Python development, making it a flexible solution for both DIY makers and professional developers building local voice assistants.
reSpeaker microphone arrays series are designed for far-field voice capture, typically supporting several meters of pickup distance depending on the environment. reSpeaker XMOS XVF3800 and reSpeaker Flex supports up to 5 meters. reSpeaker Lite supports up to 3 meters. Performance may vary based on noise levels, room acoustics, and placement.
A microphone array uses multiple microphones combined with advanced acoustic algorithms such as Acoustic Echo Cancellation (AEC), Automatic Gain Control (AGC), beamforming, and noise suppression to significantly improve sound input quality. Compared to a single microphone, it delivers better far-field voice pickup, clearer speech capture, and more reliable voice recognition in real-world environments. reSpeaker devices are specifically designed to perform well in complex or noisy scenarios such as living rooms, offices, industrial spaces, and robotics applications. The reSpeaker mic array series offers both 2-mic and 4-mic models, with multiple form factors including linear and circular arrays, as well as different mic spacing options (such as 44 mm and 66 mm), allowing users to choose the best solution for their application needs.
reSpeaker XMOS XVF3800 – AI-powered 4-Mic Array for Clear Voice Even in Noise
SKU 101991441
A professional circular 4-microphone array based on XMOS XVF3800, enabling clear target voice capture in noisy environments. Features dual modes (I2S/USB), 360° far-field voice pickup (up to 5m), on-board AI acoustic algorithms (AEC, AGC, DoA, VAD, dereverberation, beamforming, and noise suppression).
Mic Array Numbers
Voice Processor
XIAO ESP32-S3
Case
USD$54.90
You may also add
