Note:
This 100092361, Seeed Studio XIAO ESP32-S3(Tape & Reel) is specifically designed for Surface Mount Technology (SMT) production. This variant comes in a Tape & Reel package for seamless integration into automated assembly lines.
No pin headers included.
This product does not include the external antenna. If you require an external antenna,please refer to the 2.4GHz FPC Antenna for XIAO ESP32-S3
Production-Ready Design with Fusion PCBA Support
Being the 8th member of the Seeed Studio XIAO, the smallest Arduino boards for tinyML, XIAO ESP32C6 remains the classic XIAO design. All these features make it a perfect fit for either space-limited projects such as wearables, or a production-ready unit for your PCBA designs. Through our Turn Your XIAO Projects into Reality with Fusion: 30% Off PCBA - Latest News from Seeed Studio %, you can not only enjoy the lowest unit prices for all XIAO modules from our Fusion Open Parts Library, but also fabricate and scale your XIAO-based PCBA designs at low cost (30% off) with FREE Design for Manufacturing consulting services, streamlining your journey from prototype to production.
Note:
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
Starter Kit with free Course for all Electronics Neophytes and Enthusiasts
Seeed Studio has provided the Grove Starter Kit along with free and detailed courses for you quickly get started with microcontrollers and electronics, regarding all the Seeed Studio XIAO boards, promising you a great learning experience. Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
Seeed Studio XIAO Kit Courses | Seeed Studio Wiki
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs.For example, you can utilize the accelerometer on XIAO nRF52840 Sense combined with Edge Impulse to enable motion recognition by connecting with a Grove - OLED Display 0.66" (SSD1306)- IIC - 3.3V/5V. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
If you are interested in programming embedded machine learning, we have Codecraft visual programming that can help you quickly start your own TinyML project. And we have set up a #tinyml channel on our Discord server, please click to join for 24/7 making, sharing, discussing, and helping each other out.
We already have 15 XIAO products based on different solutions in the XIAO family, to help you better understand the differences and choose the most suitable part for your projects, please refer to the Seeed Studio XIAO Series Page.
Parameter | Seeed Studio XIAO ESP32-S3(Tape & Reel) | |
Processor | ESP32-S3R8 SoC | ESP32-C3 SoC |
Xtensa LX7 dual-core, 32-bit processor running up to 240 MHz | RISC-V single-core 32-bit chip processor with a four-stage pipeline that operates at up to 160 MHz | |
Wireless | Complete 2.4GHz WiFi subsystem | |
Bluetooth Low Energy 5.0 / Bluetooth Mesh | ||
On-chip Memory | 8MB PSRAM & 8MB Flash | 400KB SRAM & 4MB Flash |
Interface
| 1x UART 1x IIC 1x SPI 11x GPIO(PWM) 9x ADC 1x User LED 1x Charge LED | 1x UART 1x IIC 1x SPI 11x GPIO(PWM) 4x ADC 1x Charge LED |
1x Reset button 1x Boot button | ||
Dimensions | 21 x 17.8mm | |
Power(Typ.) | Input voltage (Type-C): 5V Input voltage (BAT): 3.7V | Input voltage (Type-C): 5V Input voltage (BAT): 3.7V |
Circuit operating Voltage: - Type-C: 5V@19mA - BAT: 3.8V@22mA | Circuit operating Voltage: - USB:5V@9mA - BAT:3.8V@9mA | |
Charging current: 50mA(Fast) / 3.8mA(Trickle) | Charging current: 380mA(Fast) / 40mA(Trickle) | |
Low Power Consumption Mode(Typ. ) (Supply Power: 3.8V) | Modem-sleep Mode: 27 mA Light-sleep Mode: 2mA Deep Sleep Mode: 14 μA | Modem-sleep Mode: 24 mA Light-sleep Mode: 3 mA Deep Sleep Mode: 44 μA |
WiFi Enabled Power Consumption(Typ. ) | Active Mode: 220 mA | Active Mode: 103 mA |
BLE Enabled Power Consumption(Typ. ) | Activex Mode: 217 mA | / |
Working Temperature | -40°C ~ 65°C | -40°C ~ 85°C |
| HSCODE | 8543709990 |
| USHSCODE | 8517180050 |
| UPC | |
| EUHSCODE | 8543709099 |
| COO | CHINA |
Seeed Studio XIAO ESP32-S3(Tape&Reel) | ×1 |
This is the Tape & Reel version of Seeed Studio XIAO ESP32-S3, designed for automated SMT assembly and high-volume production. It leverages a 240 MHz Xtensa 32-bit LX7 dual-core processor, supporting both Wi-Fi and BLE 5.0 wireless connectivity. Equipped with a 2.4 GHz rod antenna, it supports deep sleep mode with power consumption as low as 14 μA and integrates lithium battery charging management. This makes it an excellent choice for IoT applications, smart home devices, wearable electronics, and robotics projects that demand low power consumption and reliable wireless performance.
