Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
This 101991463, Seeed Studio XIAO nRF52840(Tape & Reel) is specifically designed for Surface Mount Technology (SMT) production. This variant comes in a Tape & Reel package for seamless integration into automated assembly lines and does not include pin headers.
  • Versatile Microcontroller: Incorporate the Nordic nRF52840 chip with FPU, operating up to 64 MHz, mounted multiple development ports, supported by Arduino / CircuitPython / Micropython
  • Wireless Capabilities: Implement Bluetooth Low Energy 5.4, BLE functions with onboard antenna, also provide NFC connectivity
  • Elaborate Power Design: Provide ultra-low power consumption as 5 μA in deep sleep mode while supporting lithium battery charge management
  • Thumb-sized Design: 21 x 17.8mm, Seeed Studio XIAO series classic form-factor, suitable for wearable devices
  • Perfect for Production: Breadboard-friendly & SMD design, no components on the back
Production-Ready Design with Fusion PCBA Support
All Seeed Studio XIAO dev boards feature a production-optimized SMD (Surface Mount Device) design with standardized stamp holes, making it perfect for commercial PCBA (Printed Circuit Board Assembly) integration. Through our Turn Your XIAO Projects into Reality with Fusion: 30% Off PCBA - Latest News from Seeed Studio %, you can not only enjoy the lowest unit prices for all XIAO modules from our Fusion Open Parts Library, but also fabricate and scale your XIAO-based PCBA designs at low cost (30% off) with FREE Design for Manufacturing consulting services, streamlining your journey from prototype to production.
Note:
XIAO SoM User Manual open-sources all hardware and software materials of XIAO, providing professional product design guidelines to help you accelerate ideas off the ground, streamline product design, providing a seamless experience from module selection to mass production. You can check here to see more info.
Starter Kit with free Course for all Electronics Neophytes and Enthusiasts
Seeed Studio has provided the Grove Starter Kit along with free and detailed courses for you quickly get started with microcontrollers and electronics, regarding all the Seeed Studio XIAO boards, promising you a great learning experience. Not only programming but also electronics knowledge is not required, you will be taken step by step, from understanding the basic concepts to exercising the simple projects individually, finally being able to build complex, interesting, wearable projects on your own, owing a practical electronic product prototype from the course.
You can have access to the Seeed Studio Grove ecosystem by connecting it to the compatible Seeed Studio XIAO expansion board. We have developed more than 400 Grove modules, covering a wide range of applications that can fulfill various needs.For example, you can utilize the accelerometer on XIAO nRF52840 Sense combined with Edge Impulse to enable motion recognition by connecting with a Grove - OLED Display 0.66" (SSD1306)- IIC - 3.3V/5V. Get started and explore the infinite possibilities of the Seeed Studio XIAO series!
If you are interested in programming embedded machine learning, we have Codecraft visual programming that can help you quickly start your own TinyML project. And we have set up a #tinyml channel on our Discord server, please click to join for 24/7 making, sharing, discussing, and helping each other out.
We already have 8 XIAO products based on different solutions in the XIAO family, to help you better understand the differences and choose the most suitable part for your projects, please refer to the Seeed Studio XIAO Series Page.
To better support IoT and TinyML AI projects, there is an advanced version "Tiny BLE MCU with onboard sensors for TensorFlow Lite - XIAO nRF52840 Sense" that carries an extra 6-axis IMU and a PDM microphone.
Item
Seeed Studio XIAO nRF52840 Sense
Processor
Nordic nRF52840
ARM® Cortex®-M4 with FPU runs up to 64 MHz
Wireless
Bluetooth Low Energy 5.4/Bluetooth Mesh/NFC
On-chip Memory
1 MB flash and 256 kB RAM
Onboard Memory
2 MB QSPI flash
Interface
1xUART
1xIIC
1xSPI
1xNFC
1xSWD
11xGPIO(PWM)
6xADC
Sensors
1xOnboard PDM digital microphone
1xOnboard 6-axis IMU
Dimensions
21 x 17.8mm
Power(Typ.)
Circuit operating voltage: 3.3V@200mA
Charging current: 50mA/100mA
Input voltage (VIN): 5V
Input voltage (BAT): 3.7V
Standby power consumption: <5μA
Hardware Overview
Attention:
All the I/O pins are 3.3V, please do not input more than 3.3V, otherwise, the CPU may be damaged.
  • Onboard
  • PinOut
  • Back
Application
  • Wearable devices
  • Wireless connect
  • Embedded machine learning projects
  • Perfect for mini Arduino projects
  • Tiny Machine Learning application
Certification
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
Seeed Studio XIAO nRF52840(Tape&Reel)
×1
SKU 101991463
This is the Tape & Reel version of Seeed Studio XIAO nRF52840 by Nordic. This packaging format is designed for automated SMT assembly and large-scale production. XIAO nRF52840 carries wireless capability for the first time and supports Bluetooth Low Energy 5.4, while operating with low power consumption. It will be your best microcontroller choice for Bluetooth applications.
XIAO Dev Board
Pin Header
Package
USD$9.40
You may also add
