Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
  • Power Adapter NOT included.Customers can purchase FY1209900 12V 10A Power adapter as power supply option.
  • You must use the power supply we recommend. We accept no responsibility for any robotic arm malfunctions, damage, or safety issues caused by the use of power supplies from other brands.
  • Pre-assembled Provides ready-to-use 7 DOF robot leader arm for human demonstrations, which is the perfect end-to-end learning.
  • Real-world task capable Could be used to tele-operate various motor-based arms.
  • Self-sustaining suspension Arm could be held at any position after pressing the button, enabling easier data collection.
  • LeRobot framework compatible Provides SDK under Huggingface Lerobot framework for easier data collection and training.
  • Supported ROS2, Moveit2 and Isaac Sim It supports ROS2 for publishing and subscribing to robotic arm data topics and controlling the robotic arm, and also supports MoveIt2 for inverse kinematics calculation, as well as simulation in Isaac Sim.
  • Open-Source SDK Supports Python and C++ SDK Development.
Module
Leader Arm | Violin
Degrees of Freedom
6+1
Reach
470mm
Servos
RX8-U50H-M x2
RA8-U25H-M x4
RA8-U26H-M x1
Wrist Rotate
Hold at any Position
Supported(with handle button)
Communication Hub
UC-01
Power Supply
12V / 120W (XT30 / Screw Terminal)
Weight
1.05kg
Operating Temperature
-10℃~60℃
Note:
  • Power Adapter NOT included.Leader Arm needs a 12V10A power adapter with XT30 connector or loose wires for screw terminals.
Hardware Overview
Application
Imitation learning and Reinforcement learning
The LeRobot framework is compatible with the Fashionstar star arm. It provides complete data collection, training, and deployment for teaching the robotic arm, and also has a comprehensive simulation platform. On the Nvidia Jetson edge device, it's easy and quick to train a customized robotic arm to complete grasping and placing tasks. For detailed tutorials, please refer to: LeRobot - NVIDIA Jetson AI Lab
Certification
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
Leader Arm Violin
x1
Leader Arm Violin handle
x1
C clamp
x1
Allen wrench
x1
Screw pack
x1
UC-01 debugging adapter board
x1
UC-01 debugging adapter board(backup)
x1
Note:
Power Adapters NOT included.Would need 12V10A Power Adapters with XT30 connector or loose wires for screw terminals.
Fashionstar StarAi 7 DoF Robot Leader Arm Violin, compatible with Hugging Face LeRobot
SKU 100038899
Fashionstar StarAi Arm Violin is an affordable pre-assembled servo-based 7 DOF robotic leader arm that is perfect for end-to-end learning. The demonstration training of the leader arm and the follow arm canaccomplish real-world grapsing tasks with great positional accuracy. It is a pre-assembled leader arm that can be used for demonstrations. It can be used under Huggingface LeRobot framework and ROS2.
AC/DC Power Adapter 12V 2A 5-in-1 (UK/US/EU/AU/KR Interchangeable Plugs)
USD$419.00
