USB Current Voltage Detector
Rating:
100% of 100
Rating:
100% of 100
$12.90
In stock
30+ Available
Qty Discount available
  • $11.61 /10pcs+
  • $10.97 /20pcs+
  • $10.32 /50pcs+
Small size, simple and practical tool that can detect USB's voltage and current.
It doesn't need any external power, and plug and play. And it not only voltage and current detect, but also a USB hub.
As a common USB detecter, It has large detection range, 3.2v to 10v Voltage and 0A to 3A current.
Feature:
Simple and practical
Small size
Convenient to carry
No external power
Plug and play
Specification:
Min supply voltage: +3.2 V
Max supply voltage: +10 V
Measuring Range:DC 3.2-10V
Operating temperature: -10 to 65° c
Operating Humidity: 10 ~ 80% (no condensing)
Working pressure: 80 ~ 106kPa
Display Type:Digital Only
Operating Temperature:-10 to 65° c
Brand Name:DC Voltmeter Ammeter
Accuracy Class:1% (± 2 digit)
Dimensions:69 x 26 x 19mm
Model Number:YB26VA 2in1 DC Volt Amp Meter
USB extension cable:≥ 120mm
Display:0.28 "LED red
Measuring rate:≥ 500mS / times
Operating Current:<20mA
Measure current:3A
Test Current: 0 ~ 3A (Max 10A, but the error is big, cannot work for a long time)
Dimensions 80mm x120mm x14mm
Weight G.W 29g
Battery Exclude
USB Current Voltage Detector 1
ECCN ERA99
HSCODE 9030849000
USHSCODE 8473102000
UPC 841454102069
Product Faqs
Sort by
