Wifi Shield (Fi250) V1.1
Rating:
67% of 100
Rating:
67% of 100
$44.90
In stock
7 Available
Qty Discount available
  • $40.41 /10pcs+
  • $38.17 /20pcs+
  • $35.92 /50pcs+
Wifi Shield (Fi250) V1.1 is a economic internet solution with Arduino. The Wi-Fi module support IEEE 802.11b/g/n mode, maximum speed up to 65Mbit/s. Wifi Shield (Fi250) V1.1 combine on board antenna; it’s easy to build you project in a small box. The module reserve a UFL connector, you can use an extra antenna to improve the signal range. There is a key on the board, just push one time to change wifi shield as AP mode. The module have a computer interface software, you can control and upgrade the module via USB-UART convertor. The wifi shield contain a Micro SD card socket, it’s like a recorder when wifi shield working as TCP, UDP server.
Features:
  • Module: WIZnet FI250
  • Operating Voltage: 5V or 3.3V (Auto select)
  • Current: 300mA (maximum)
  • Single band: 2.4GHz IEEE 802.11b/g/n
  • Antenna: On board PCB antenna (reserver UFL connector)
  • Memory: 1MB Flash Memory, 128KB SRAM, 1MB Serial Flash
  • Interface: UART(default)/SPI(upgrade firmware)
Documents:
Dimensions 115mm x80mm x25mm
Weight G.W 46g
Battery Exclude
Wifi Shield (Fi250) V1.1 1
ECCN 5A002.a.1
HSCODE 8517709000
Wiki of Wifi Shield (Fi250) V1.1
Product Faqs
Sort by
Tags:
