Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Pre-installed Jetpack : Pre-installed Jetpack 6.2.2 and supports Jetpack 7.2. Includes Jetson Linux 36.5 featuring Linux Kernel 5.15, UEFI based bootloader, Ubuntu 22.04 based root file system, NVIDIA drivers, necessary firmwares, toolchain and more.
  • Most powerful AI developer kit for edge computing: up to 275 TOPS, 8 times AI performance compared to Jetson AGX Xavier. Power configurable between 15W and 60W.
  • Onboard memory: 64GB LPDDR5, 204 GB/s of memory bandwidth, and 64 GB of eMMC 5.1.
  • High-speed interface support for multiple sensors: PCIe x 16 Connector, 1x 10GbE, 1x Display Port, 16 lanes of MIPI CSI-2, USB 3.1 interfaces, and a 40-pin header.
  • Camera connection: Compatible with third-party camera expansion boards that are compatible with NVIDIA® Jetson AGX Orin™ 64GB Developer Kit
  • No sales limit: Available at any quantity as needed, enabling mass volume deployment and project acceleration.
Module Specification
Jetson AGX Orin 64GB System on Module
AI PerfromanceJetson AGX Orin 64GB - 275 TOPS
GPUNVIDIA Ampere architecture with 2048 NVIDIA® CUDA®cores and 64 Tensor cores
CPU12-core Arm Cortex-A78AE v8.2 64-bit CPU 3MB L2 + 6MB L3
DL Accelerator2x NVDLA v2.0
Vision AcceleratorPVA v2.0
Memory64GB 256-bit LPDDR5 204.8GB/s
Storage64GB eMMC 5.1
Video Encode2x 4K60 | 4x 4K30 | 8x 1080p60 | 16x 1080p30 (H.265)
Video Decode1x 8K30 | 3x 4K60 | 7x 4K30 | 11x 1080p60 | 22x 1080p30 (H.265)
Power15W-60W
Carrier Board Specification
Carrier Board
Storage1x M.2 Key M - 4 x PCIe Gen 4(128G SSD module included)
NetworkEthernet1x RJ45 - Up to 10GbE
M.2 KEY E1x PCIe Gen 4, USB 2.0, UART, I2S(Wireless module included)
I/OUSB2x USB 3.0 Type-C;
4x USB 3.1 Type-A
1x USB 2.0 Micro-B
Camera16 lane MIPI CSI-2 connector
DisplayDisplayPort 1.4a (+MST)
Fan1x 4-pin Fan header
PCIe16x PCIe slot supporting:8x PCIe Gen4
RTC2-pin RTC battery backup connector
Other
40-pin header (I2C, GPIO, SPI, CAN, I2S, UART, DMIC) 12-pin automation header
10-pin audio panel header
10-pin JTAG header
DC power jack
Power, Force Recovery, and Reset buttons
Power9-20V
Dimension110mm x 110mm x 73mm(Height includes feet, carrier board, module, and thermal solution)
Warranty1 year
Hardware Overview
Application
  • Jetpack 7.2 update
Use Jetson Develop Tool to update to Jetpack 7.2 for agentic AI skills package, Yocto BSP and memory optimization. Learn more about Jetpack 7.2 here and a deep dive into what you can get from Jetpack 7.2.
  • reComputer AI Lab
Seeed offers reComputer AI lab, a platform that helps you deploy AI applications with one-click tools and ready-to-use resources. It includes optimized edge AI model demos for CV, LLM, VLM, interactive tutorials, deployment tools, containerized applications, and community projects to speed up development on Jetson.
  • Jetson Examples
We have Jetson-example prepared for you! It offers one-line deployable projects compatible with generative AI large models, including LeRobot, Ollama, Qwen, etc; with computer vision such as Ultraslytics YOLO26. We have configured all environment setups for you to provide a single command deployment of projects, easy to try out/verify if the trending model performance is suitable for your GPU needs and application scenarios.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOChina
reComputer Classic J5012x1
Power Adapter AC Power 19V 4.94Ax1
USB-C Cablex1
Type B (US, CA, JP) Power Cablex1
Type I (CN) Power Cablex1
Type B (TW) Power Cablex1
UPC Labelx1
Quick Start and Support Guidex1
reComputer Classic J5012, Ultimate AI Developer Kit with NVIDIA® Jetson AGX Orin™ 64GB
SKU 100003716
reComputer Classic J5012 is a powerful developer kit built around the NVIDIA® Jetson AGX Orin™ 64G module. It features a rich set of I/O interfaces, including USB, 10Gb Ethernet, PCIe expansion, and a 40-pin expansion header—making it an ideal platform for embodied AI and edge AI prototyping. Designed as a direct replacement for the NVIDIA® Jetson AGX Orin™ 64GB Developer Kit, it offers full compatibility with the existing ecosystem of the offical developer kit and is compatible with the offical Jetpack.
USD$3999.00
