Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note: This SKU includes the RK3576 Compute Module, IO Board, and RK1820 M.2 AI Accelerator. The onboard M.2 M-Key slot is occupied by the included RK1820 accelerator in this configuration.
The reComputer RK3576 Module Dev Kit combines the Rockchip RK3576 Compute Module and a feature-rich IO Board into a complete development platform for edge AI prototyping and system validation.
Powered by an 8-core CPU and 6 TOPS NPU, the kit provides M.2 expansion, Gigabit Ethernet with PoE PD, HDMI, USB-C DisplayPort, MIPI DSI, MIPI CSI, USB, GPIO, audio, and storage interfaces, enabling developers to quickly evaluate computing performance, AI workloads, peripherals, and system architecture.
Together with reComputer AI Lab, developers can accelerate the deployment of computer vision, large language models, vision-language models, and speech AI before moving to custom carrier board development.
Feature 1. Complete Rockchip RK3576 Evaluation Platform
Move from a bare compute module to a complete development platform without designing a custom carrier board at the beginning of your project.
The Dev Kit combines the Rockchip RK3576 Compute Module with an IO Board and RK1820 AI Accelerator that exposes the module's key interfaces through standard connectors, allowing developers to evaluate hardware, software, peripherals, and system architecture on one platform.
  • RK3576 Compute Module
  • RK1820 AI Accelerator
  • IO Board in one kit
  • Ready for hardware and software evaluation
  • Simplifies peripheral and interface validation
  • Reduces early-stage custom carrier board development
  • Provides a reference platform for future product integration
Use the Dev Kit to validate the system first, then move to a custom carrier board when the product architecture is confirmed.
Feature 2. 8-Core Computing with 6 TOPS Edge AI
At the core of the Dev Kit is the Rockchip RK3576 processor, combining heterogeneous CPU computing with dedicated hardware AI acceleration.
8-Core CPU
The reComputer RK3576 features an advanced CPU architecture with
  • 4 × Cortex-A72 @2.2GHz
  • 4 × Cortex-A53 @2.0GHz
  • LPDDR5 (4GB/8GB/16GB)
  • ARM Mali GPU-G52 MC3
6 TOPS RK3576 NPU
With a built-in 6 TOPS NPU, it delivers efficient AI inference directly on the device, reducing latency and enhancing privacy without relying on the cloud.
  • Vision CNN: [email protected](640\*640)
  • LLM: capable of deepseek-r1-distill-qwen 7b support
  • VLM: capable of qwen2.5-vl 3b
  • STT: whisper_base_20s (RTF 0.218) with real-time processing support
  • TTS:mms_tts_eng_200 (RTF 0.069) with real-time processing support
Check the details of the benchmark.
Feature 3. Dedicated 20 TOPS AI Acceleration for LLM, VLM and CV
The Rockchip RK1820 AI accelerator adds a dedicated 20 TOPS INT8 NPU and 2.5 GB of on-chip DRAM to the RK3576 host platform, providing dedicated acceleration for local AI workloads.
Local LLM and VLM
Run optimized lightweight LLMs and vision-language models locally, including 3B-class workloads. The platform is well suited for building local AI assistants, edge AI agents, visual question-answering systems, image-understanding applications, and industrial copilots—while keeping sensitive data on-device. Supported deployments include optimized Qwen, DeepSeek, and other LLM and VLM models compatible with the RKNN3 software stack.
Computer Vision
Accelerate RKNN3-compatible computer vision models, including the YOLO family, for object detection, classification, segmentation, tracking, visual inspection, and video analytics.
Feature 4. reComputer AI Lab for Faster AI Deployment
The Dev Kit is supported by reComputer AI Lab, providing a streamlined workflow for model conversion, deployment, and evaluation on the RK3576 platform.
  1. Computer Vision: Object detection, segmentation, tracking, and video analytics
  2. LLM & VLM: Local language and multimodal AI applications with models such as DeepSeek and Qwen
  3. Speech AI: Offline speech recognition and voice interaction with models such as Whisper
With containerized and simplified deployment workflows, reComputer AI Lab reduces environment setup and helps developers move from AI models to on-device evaluation faster. Explore reComputer AI Lab →
Feature 5. Rich I/O and High-Speed Expansion
The Dev Kit exposes a broad range of RK3576 interfaces for connecting storage, displays, cameras, networking, sensors, and other embedded peripherals.
1. 40-Pin GPIO Expansion
A 40-pin GPIO expansion header provides convenient access to general-purpose interfaces for connecting sensors, actuators, controllers, and other embedded peripherals.
It enables developers to quickly build physical prototypes without designing additional interface hardware during early-stage validation.
2. Additional Native Interfaces
The Dev Kit also provides interfaces including:
  • USB;GPIO;Audio;Storage;MIPI CSI;MIPI DSI;HDMI;USB-C DisplayPort;Gigabit Ethernet
Feature 6. Unlock the Raspberry Pi Expansion Ecosystem
This Dev Kit supports compatible Raspberry Pi peripherals
  • Vision: Raspberry Pi Camera Module 3
  • Display: Official 7-inch DSI Display
  • Power & Expansion: PoE+ HAT and other compatible accessories
Build flexible solutions for machine vision, interactive displays, and Power over Ethernet applications.
Feature 7. Gigabit Ethernet with PoE PD
The Dev Kit provides a native Gigabit Ethernet RJ45 port for high-bandwidth network connectivity.
Integrated IEEE 802.3at PoE PD support enables both power and network connectivity through a single Ethernet cable.
This is especially useful when prototyping smart cameras, AI terminals, gateways, and remotely deployed edge devices.
Feature 8. High-Resolution Video Processing
The Rockchip RK3576 integrates dedicated video processing hardware for high-resolution multimedia and vision applications.
Video Decoding
  • 8K @ 30fps: H.265 / VP9 / AV1 / AVS2
  • 4K @ 60fps: H.264
Video Encoding
  • 4K @ 60fps: H.265 / H.264
These capabilities make the platform suitable for high-resolution video analytics, smart cameras, multimedia terminals, and other video-intensive edge applications.
Parameter
Hardware Specification
Product Series
reComputer RK3576 Module Dev Kit with RK1820 AI Accelerator
SOC
Rockchip RK3576
CPU
GPU
ARM Mali-G52 MC3
NPU
INT8@6TOPS
RK3576 NPU: INT8 @ 6 TOPS
RK1820 AI Accelerator: up to 20 TOPS (INT8)
Operating System
Armbian (pre-installed), Debian, Ubuntu, Android 14+, and balenaOS support
RAM
LPDDR5: 8GB
Onboard Storage
eMMC: 64GB
System Specification
Power Input
DC 9V~19V
PoE
1 x PoE PD*
Power
Yes
Reset
Yes
MaskROM
Yes
Interface
Ethernet
1x Gigabit Ethernet with PoE support(Additional PoE Module Required)
USB
1 × USB 3.0 Type-A, 2 × USB 2.0 Type-A
1 × USB-C for USB OTG & DisplayPort
Display
1x Display; 1x DP1.4 via USB Type C port; 1x 4-lane MIPI DSI(22pin)
GPIO
1x 40-Pin Expansion header
SD Card
1x Micro SD Card Slot
M.2 Slot
1x M.2 Key M 2280 slot (PCIe 2.1x 1), supporting either an NVMe SSD or an AI accelerator
LED
1x Power; 1x Status
Button
1x Power; 1x Reset; 1x MaskROM
Audio
1x 3.5mm Headphone Jack with Microphone Input
CSI Camera
1x 4-lane MIPI CSI(22pin);1x 2-lane MIPI CSI(22pin)
Fan Connector
1 × 4-pin PWM fan connector
RTC Backup
1 × CR2032 RTC battery holder
Power Input
9–19V DC via DC jack or 2-pin power header
Wireless Communication
Wi-Fi
Onboard WiFi6 with FPC Antenna
BLE
BT5.4 with FPC Antenna
Ambient Conditions
Operating Temperature
0 ~ 65°C
Others
Heat Dissipation
Fan
Warranty
1 years
Production Lifetime
Until January 2036
Statement
Options marked with * require additional purchase according to the accessories list.
Hardware Overview
Application
Build Vision-Enabled Edge Products
Prototype camera-based products for inspection, monitoring, retail analytics, and other real-time on-device vision applications.
Create Private Multimodal AI Devices
Develop local AI assistants that combine language, vision, and voice processing while keeping sensitive data on-device.
Accelerate Custom Edge AI Product Development
Validate the AI software stack and overall product architecture before moving from the Dev Kit to a custom carrier board.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COO
reComputer RK3576 Module 0864x1
reComputer RK3576 Module IO Boardx1
AI Acceleratorx1
12V/3A Power Adapter (with 1x US/EU/UK/AU Plugs)x1
32GB microSD Cardx1
Active Cooling System (Heatsink & Fan, pre-assembled)x1
Wi-Fi/BT FPC Antennax1
Wi-Fi/BT External Rod Antennax1
reComputer RK3576 Dev Kit with RK1820 AI Accelerator | High Performance Rockchip Industrial Edge Al Platform
SKU 100085993
It's a heterogeneous edge AI development kit combining the Rockchip RK3576 6 TOPS NPU with an RK1820 20 TOPS AI accelerator and 2.5 GB on-chip DRAM. With M.2, 200-Pin B2B Connector, PoE PD Gigabit Ethernet, HDMI, MIPI CSI/DSI, GPIO, up to 16GB LPDDR5 RAM/128GB eMMC, and reComputer AI Lab, it accelerates local LLM, VLM, computer vision, and multimodal AI development—from prototyping to custom product validation.
USD$379.00
You may also add
