Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
The reComputer RK3576 Module IO Board is designed to accelerate development with the reComputer RK3576 Module by converting its high-density board-to-board interfaces into standard, development-ready connections.
It provides Gigabit Ethernet with PoE PD, M.2 M-Key, HDMI 2.1, USB-C DisplayPort, MIPI DSI, MIPI CSI, USB, GPIO, audio, and storage interfaces, enabling engineers to quickly build and validate complete RK3576-based systems.
It is ideal for RK3576 module evaluation, peripheral validation, camera and display integration, custom carrier board development, and Embedded Linux or Android bring-up.
Feature1. Rapid RK3576 Module Prototyping
Convert the reComputer RK3576 Module into a development-ready system without designing a custom carrier board from scratch.
The IO Board breaks out the module’s high-density interfaces into standard connectors, making it easier to evaluate the RK3576 platform, validate peripherals, develop software, and prototype complete edge computing systems.
  • Designed for the reComputer RK3576 Module
  • Standard interfaces for rapid hardware integration
  • Suitable for module evaluation and peripheral validation
  • Useful as a reference platform before custom carrier board development
Feature2. Rich I/O for Peripheral Integration
Access a broad range of native RK3576 interfaces through standard development-ready connectors.
The board integrates display, camera, networking, storage, USB, GPIO, and audio connectivity on a single platform, reducing the need for additional adapter boards during prototyping.
Key interfaces include:
  • Gigabit Ethernet
  • PoE PD
  • M.2 M-Key
  • HDMI 2.1
  • USB-C with DisplayPort
  • MIPI DSI
  • MIPI CSI
  • USB
  • GPIO
  • Audio
  • Storage interfaces
Feature3. M.2 NVMe Storage and AI Expansion
The onboard M.2 M-Key 2280 slot provides PCIe 2.1 ×1 connectivity for high-speed storage and compatible PCIe expansion devices.
It can be used with compatible NVMe SSDs for local storage and data logging, or with compatible M.2 AI accelerators for additional edge AI computing capability.
Highlights:
  • 1× M.2M - Key slot(PCIe 2.1 ×1)
  • Supports compatible NVMe SSDs
  • Supports compatible M.2 AI accelerators
Compatibility of individual M.2 devices may depend on power, driver, and operating system support.
Feature4. Gigabit Ethernet with PoE PD
The board provides 1× native Gigabit Ethernet RJ45 port for reliable high-bandwidth network connectivity.
Integrated IEEE 802.3at PoE PD support allows the RK3576 system to receive both network connectivity and power through a single Ethernet cable, simplifying deployment of network-connected edge devices.
Highlights:
  • 1× Gigabit Ethernet RJ45
  • IEEE 802.3at PoE PD support
  • Power and data over a single Ethernet cable
  • Suitable for networked edge computing and remote device deployment
Feature5. Flexible Display Connectivity
The IO Board provides multiple native display interfaces for developing interactive terminals, embedded displays, dashboards, and multi-screen applications.
Display interfaces:
  • 1× HDMI 2.1: supports display output up to 4K @ 120Hz
  • 1× USB-C DisplayPort 1.4: supports display output up to 4K @ 60Hz
  • 1× 4-lane MIPI DSI: enables direct integration with compatible embedded displays
Multiple display interfaces give developers greater flexibility when evaluating different display architectures and building RK3576-based visual applications.
Actual resolution, refresh rate, and simultaneous display capability depend on the connected display, system configuration, software, and RK3576 platform support.
Parameter
Hardware Specification
Product Series
reComputer RK3576 Module lO Board
System Specification
Power Input
DC 9V~19V
PoE
1 x PoE PD*
Power
Yes
Recover
Yes
MaskROM
Yes
Interface
Ethernet
1x Gigabit Ethernet with PoE support(Additional PoE Module Required)
USB
1x Type A USB 3.0; 2x Type A USB 2.0;
1x Type C for OTG & DP
Display
1x Display; 1x DP1.4 via USB Type C port; 1x 4-lane MIPI DSI(22pin)
GPIO
1x 40-Pin Expansion header
SD Card
1x Micro SD Card Slot
M.2 Slot
1x M.2 Key M 2280 slot (PCIe 2.1x 1), supporting either an NVMe SSD or an AI accelerator
LED
1x Power; 1x Status
Button
1x Power; 1x Reset; 1x MaskROM
Audio
1x 3.5mm Headphone Jack with Microphone Input
CSI Camera
1x 4-lane MIPI CSI(22pin);1x 2-lane MIPI CSI(22pin)
Fan Connector
1 × 4-pin PWM fan connector
RTC Backup
1 × CR2032 RTC battery holder
Power Input
9–19V DC via DC jack or 2-pin power header
Standards
Certification
CE, FCC
TELEC
RoHS
Ambient Conditions
Operating Temperature
0 ~ 65°C
Others
Warranty
1 years
Production Lifetime
Until January 2036
Statement
Options marked with * require additional purchase according to the accessories list.
Hardware Overview
Application
Development & Expansion with RK3576 Module
  • AI Vision and Industrial Inspection
  • Smart Cameras and PoE Edge Devices
  • Interactive AI Terminals
  • Local LLM, VLM, and Speech AI Evaluation
  • Custom Edge AI Product Development
Certification
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8473308000
COOChina
reComputer RK3576 Module IO Boardx1
reComputer RK3576 Module IO Board: Rapid Prototyping and I/O Expansion Board for reComputer RK3576 Module
SKU 100073450
It’s a development carrier board for the reComputer RK3576 Module, exposing high-density B2B interfaces for rapid edge AI and embedded Linux development. With Gigabit Ethernet PoE PD, M.2 M-Key, HDMI, USB-C DP, MIPI CSI/DSI, GPIO, and USB, it streamlines peripheral validation and custom carrier-board design.
USD$18.00
You may also add
