Other things you might like
Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Boosted AI Performance in a compact size: Delivers up to 157 TOPS AI performance by NVIDIA® Jetson™ Orin™ NX 16GB module in Super/MAXN mode.
  • Rich Interfaces for Robotics: Including dual RJ45, M.2 slots for 5G/Wi-Fi/BT modules, 6x USB 3.2, 2x CAN, GMSL2, I2C, and UART, functioning as a powerful robotic brain.
  • Industrial-Grade Power and Thermal Design: Operates reliably from –20 °C to 60 °C in 25 W mode and up to 55 °C in MAXN mode, fueled through a wide 19–54 V DC input, ensuring stable operation in mobile and industrial robot environments
  • Software-ready Ecosystem: Pre-installed with JetPack 6.2 and Linux BSP for seamless deployment. Combined with Isaac Sim, it can be used to create autonomous mobile robots (AMRs), arms and manipulators, humanoids, and more.
  • Ready-to-use GMSL Extension: Provides ready-to-use GMSL extension that supports multiple GMSL cameras in Jetpack
    Jetson Modules Performance with Super Mode
    • Enhanced power management
    • Improved higher frame rate processing
    • Reduced inference time
Module
reComputer Robotics J4012
Applications Processor(AP)
NVIDIA Jetson Orin™ NX 16GB
AI Performance
Orin NX 16GB – 157 TOPS (MAXN)
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
GPU Max Frequency
1173 MHz
CPU
8-core NVIDIA Arm® Cortex A78AE v8.2 64-bit CPU 2MB L2 + 4MB L3
CPU Max Frequency
2.0 GHz
DL Accelerator
2 x NVDLA v2.0
DL Max Frequency
1.23 GHz
Vision Accelerator
1 x PVA v2.0
Memory
16GB 128-bit wide LPDDR5 DRAM 102.4GB/s
Power
10W - 15W - 25W - 40W
Video Encode
1x 4K60 (H.265)
3x 4K30 (H.265)
6x 1080p60 (H.265)
12x 1080p30 (H.265)
Video Decode
1x 8K30 (H.265)
2x 4K60 (H.265)
4x 4K30 (H.265)
9x 1080p60 (H.265)
18x 1080p30 (H.265)
CSI camera
Up to 4 cameras
(8 via virtual channels)
8 lanes MIPI CSI-2
D-PHY 2.1 (up to 20Gbps)
Mechanical
69.6mm x 45mm
260-pin SO-DIMM connector
Carrier Board
Storage
1x M.2 KEY M PCIe
Networking
M.2 KEY E
1x M.2 Key E for WiFi/Bluetooth module
M.2 KEY B
1x M.2 Key B for 5G module
Ethernet
2x RJ-45 Gigabit Ethernet
I/O
USB
6x USB 3.2 Type-A (5Gbps)
1x USB 3.0 Type-C (Host/DP 1.4)
1x USB 2.0 Type-C (Device Mode Only for Reflash/Debug)
CAN
2x CAN0 (XT30(2+2))
3x CAN1 (4-Pin GH-1.25 Header)
Display
1x DP1.4 (Type C Host)
UART
1 x UART 4-Pin GH-1.25 Header
I2C
2x I2C 4-Pin GH-1.25 Header
Fan
1x 4-Pin Fan Connector (5V PWM)
1x 4-Pin Fan Connector (12V PWM)
Extension Port
1x Camera Expansion Header (for GMSL2 board, included)
RTC
1x RTC 2-pin (3V)
1x RTC Socket (3V, CR1220 no included)
LED
3x LED (PWR, ACT and User LED)
Pinhole Button
1x PWR
1x RESET
DIP Switch
1x REC
Antenna Hole
5x Antenna Hole
Power
19-54V XT30(2+2) (XT30 to 5525 DC Jack Cable included)
Jetpack Version
Jetpack 6.2
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 66mm
Weight
1100g
Installation
Desk, Wall-mounting
Operating Temperature
-20℃~60℃ (25W Mode)
-20℃~55℃ (MAXN Mode)
(with reComputer Robotics heat sink with fan)
Warranty
2 Years
Certification
(Pending)
RoHS, CE, FCC, KC
Cameras Supported in Jetpack
Manufactuer
Model
Resolution
Sensing
SG3S-ISX031C-GMSL2F
1920H*1536V
SG2-AR0233C-5200-G2A
1920H*1080V
SG2-IMX390C-5200-G2A
1920H*1080V
SG8S-AR0820C-5300-G2A
3840H*2160V
Orbbec
Orbbec Gemini 335LG
3D
Hardware Overview
Application
Humanoid Robot & Manipulation:
Serving as a powerful brain for humanoid robots, the reComputer Robotics series delivers rich perception with precise motion control. Emulating human-like sensing, dexterity, mobility and whole-body coordination—seamlessly collaborating with people to get tasks done.
Autonomous Robots, AMRs/ AGVs/ Logistics Robots:
  • The CAN bus links servos or motors to drive Robotic Arms and Autonomous Robots with millisecond-level joint coordination.
  • Logistics Robots map in seconds via UART LiDAR, dodge on the fly and shuttle racks nonstop.
  • I²C weaves temperature, humidity, IMU and fuel-gauge data into a net, giving robots early-maintenance alerts.
  • USB cameras scan barcodes while on the move, and a USB ticket printer labels parcels in real time—zero manual labor from inbound to outbound.
  • Dual-RJ45 link-aggregation delivers video to the Edge AI reCopmputer in <1 ms for real-time QC and remote monitoring.
High-Performance Vision for Robotics:
Combining a GMSL 2 camera with a reComputer Robotics enables advanced vision-based robotics. Sensing 3MP GMSL 2 camera supports real-time object detection, panoramic environment awareness, and multi-camera 3D reconstruction . The high-bandwidth, low-latency GMSL 2 link supports long cable runs and multi-camera setups, while the Jetson Orin NX delivers real-time AI processing for perception, mapping, and control.
3D Vision and GMSL 2 Connectivity for Robotics:
The reComputer Robotics GMSL Extension supports the Orbbec Gemini 335LG Stereo Vision 3D Camera, providing accurate real-time 3D perception for advanced robotics. With the MAX96712 deserializer and mini-FAKRA connector, it ensures secure, low-latency, and reliable data transmission, ideal for AMRs, robotic arms, and collaborative robots. Precise depth sensing enables smarter navigation, robust object recognition, and reliable obstacle avoidance across mobile robots, delivery systems, and shelf-stocking applications.
Certification
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
Items
Quantity
Jetson Orin™ NX 16GB module
x 1
Seeed Carrier Board (reComputer Robotics J401) with GMSL Extension
x 1
128GB NVMe SSD
x 1
Aluminum Case and Heatsink with Fan
x 1
USB Cable; Type A to Type C
x 1
XT30 to DC cable
x1
User Manual
x 1
GMSL2 cameras can be used with NVIDIA Jetson-based systems that integrate a compatible GMSL2 serializer/deserializer and Mini-FAKRA/FAKRA interfaces. At Seeed, we offer NVIDIA Jetson-based devices with built-in GMSL support, such as the reComputer Robotics J4012 and J3011 "with GMSL" configurations, which allow you to directly connect supported GMSL2 cameras. For custom designs, our reServer Industrial J501 carrier board for Jetson AGX Orin can be combined with a suitable GMSL extension board to support multiple GMSL camera inputs.
reComputer Robotics J4012 with GMSL Extension - Intelligent Edge AI Computer with NVIDIA Jetson Orin NX Super 16GB
SKU 100026552
The reComputer Robotics J4012 with GMSL Extension is a compact, high-performance edge AI box designed for advanced robotics development. Compatible with NVIDIA® Jetson™ Orin™ NX modules in Super/MAXN mode, it delivers up to 157 TOPS of AI performance, leveraging up to 1.7x improvement over its predecessor. Pre-installed with JetPack 6.2 and Linux BSP, it ensures seamless deployment, serving as a powerful robotic brain capable of processing complex data from various sensors, including GMSL cameras.
Series
Processor
Memory
GMSL
USD$1639.00
You may also add
