Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Rugged design for harsh working environment: IP65 front panel, -10\~50°C operating temperature
  • Open-source design in software and hardware: Powered by Raspberry Pi CM4, easy for customization or derivatives with the PCIe extensions design (flexible for NVME SSD, Dual 1000M Ethernet, Dual USB 3.0, COM Port RS485/232, and more customizations)
  • Cost-effective Device Master: HMI, PLC, Panel PC and gateway all-in-one. Perfect for the distributed hub devices
  • Low code programming for event-driven applications: Natively integrated Node-RED for flow-based editing and one-click deployment, compatible with all software runs on Raspberry Pi
  • Hybrid connectivity: Support 4G LTE, LoRaWAN®, Wi-Fi, BLE, RS485/RS232, CAN bus, 1000M Ethernet, USB, HDMI
  • Product Warranty: Two-year warranty
Note: Product Lifetime: at least until 2034 (Based on Raspberry Pi)
Basic
CPUCM4 Quad-core Cortex-A72@ 1.5GHz
Memory8GB
Storage64GB eMMCM.2 NVMe SSD Slot 2280-M Key (optional)
OS SupportRaspbianSenseCraft Edge OS
Display
Size10.1''
Max. Resolution1280 x 800
Max. Colors16.7M (8-bit)
Luminance (nit)400
Viewing Angle (H/V°)170/170
Backlight Life (hrs)30000
Touch Type10-point Capacitive
Pencil Hardness7H
Video&Audio
VideoHDMI2.0
Audio2 x MicrophoneBuzzer3.5mm Audio Jack
CameraCSI (optional)
Interfaces
Ethernet1 x 10/100/1000 Mbps2 x 10/100/1000 Mbps (optional)
USB2 x USB-A 2.0 Host
RS4851 x RS485 > Terminal Block1 xRS485 > DB9 (optional)
RS2321 x RS232 > Terminal Block1 x RS232 > DB9 (optional)
CAN1 x CAN-BUS > Terminal Block
DI4 x DI > Terminal Block
DO4 x DO > Terminal Block
40pin GPIOInside
Wireless Communication
Wi-FiOn-chip Wi-Fi
BLEOn-chip BLE
LoRa®Mini-PCIe for LoRaWAN® (optional)
CellularMini-PCIe for 4G (optional)
Power
Input2-pin Terminal Block
PoE12.95W PoE (optional)
Power Range12~24V DC
Power Consumption6W Typ.9W Max.
Power SwitchNO
Reboot SwitchYES
Environment
Ingress ProtectionIP65 Front Panel
Operating Temperature-10~50 °C
Storage Temperature-20~70 °C
Humidity (Operating)10~95% RH
Mechanical
Dimension (W x H x D)259.4 x 191 x 42.2 mm
EnclosureDie-cast Aluminum Alloy
MountingPanel, VESA, DIN-rail
Weight (Net)1.8Kg
Vibration Resistance5 Grms random vibration (5 ~ 500Hz) during operation, IEC60068-2-64
Shock ResistanceOperating 50 G peak( 11ms duration), IEC 60068-2-27
Certification
CE, FCC, UCKA, RoHS, TELEC, REACH
EMC
ESDEN61000-4-2, Level 3
EFTEN61000-4-4, Level 2
SurgeEN61000-4-5, Level 2
Others
RTCHigh Accuracy RTC (with a CR2032 battery)
Hardware WatchDog1~255s
SecurityATECC608A
Warranty2 Years
Heat DissipationFanless
Hardware Overview
reTerminal DM is an integrated device master that can function as an HMI/PLC/Gateway/Panel PC all-in-one device, working in the edge layer of the IOT architecture, unifying data flow, and managing onsite devices, reducing the big gap between legacy systems and modern IT infrastructures in various application scenarios.
Application
The reTerminal DM HMI presents a versatile solution applicable across numerous industries. Seamlessly integrating cutting-edge technologies, it streamlines operations and enhances efficiency. Running on the Home Assistant platform and employing Computing Vision, Cloud solutions, and platforms like N3uron, Ignition Edge, and Node-RED, along with our proprietary platform, Sensecraft Edge OS, it opens up exciting possibilities for developers and enthusiasts alike.
  • Energy Management: Monitor grids, monitor and maintain solar panels.
  • Building Management: Central control panel for BAS, individual room control panels.
  • MedTech: Medical device control panel, patient monitoring station.
  • Construction: BIM, Monitor sites, control heavy machinery.
  • Transportation: Monitor vehicle health, control ticketing systems (buses, trains).
  • Agriculture: Control irrigation systems, monitor greenhouse conditions.
  • Retail: Display digital signage, control self-checkout kiosks.
  • Logistics: Track inventory movement, manage warehouse operations.
  • Water Management: Monitor water treatment plants, control water distribution.
Certification
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COO
Basic
Memory8GB
Display
Size10.1''
Luminance (nit)400
Pencil Hardness7H
Video&Audio
VideoHDMI2.0
Interfaces
40pin GPIOInside
Wi-FiOn-chip Wi-Fi
BLEOn-chip BLE
Power
Power SwitchNO
Reboot SwitchYES
Environment
Mechanical
Weight (Net)1.8Kg
Certification
EMC
Others
SecurityATECC608A
Warranty2 Years
reTerminal DM - 10.1'' HMI| CM4108064 | Raspberry Pi Rugged Panel PC | Panel Controller
SKU 100055964
reTerminal DM is a Panel PC, HMI, IIoT Gateway all-in-one device powered by Raspberry Pi CM4, with 10.1'' IP65 front panel and supports Raspberry Pi-based software ecosystem.It is equipped with rich interfaces, supporting CAN bus, RS485, RS232, Gigabit Ethernet, as well as powerful wireless communication capabilities such as 4G, LoRa®, Wi-Fi, and BLE.
Model
Display Size
RAM
eMMC
USD$525.90
