seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      RFbee V1.1 - Wireless arduino compatible node
      SKU 113050002
      $19.50
      10 Available
      $19.50/1pcs+
      $17.55/10pcs+
      $16.57/20pcs+
      $15.60/50pcs+
      ADD TO CART
      The RFBee is a RF module providing easy and flexible wireless data transmission between devices. It is based on a AVR Atmega168 working as a fully functional Arduino connected via SPI to a TI CC1101 RF transceiver.
      • Range: indoor/Urban: up to 50m; Outdoor line-of-sight: up to 120m;
      • Receiver sensitivity: -95dBm
      • RF data transmission rate: 4,800bps; 76,800bps
      • Working frequency : 868MHz & 915MHz
      • Communication type: Point to Point, or Point to Multipoint.
      • Easy-to-Use serial interface and rich extendable ports
      • Easy-to-Use AT command: Set working mode, Serial Baud Rate, etc.
      • Open source hardware and firmware
      • Socket compatible with the Xbee, so you can plug it into any Xbee socket as a quick replacement.
      Note
      only the Rx,Tx, VCC, GND pins are identical to the Xbee. RFbee will not communicate with Xbee, so RFbee need to be used on both ends of the wireless connection.
      Technical Details
      Dimensions60mm x 60mm x 13mm
      WeightG.W 4g
      BatteryExclude
      RFbee V1.1 - Wireless arduino compatible node1
      Reviews
      Questions and Answers
      SUBMIT
      0
      Does this module require the wireless shield as well?
      on Oct 19,2016
      Replyupvote ()
      HI,it need not wireless shield.
      on Jan 16,2018 11:12 AM
      Replyupvote ()
      Reply
      0
      Hi, ive a kit with 2 nodes... one i would like to use as master and the other as slave, but i dunno how to start! where can i see a tutorial to help me with the basic to start?
      on Oct 19,2016
      Replyupvote ()
      <p>Please refer to its wiki page which includes hardware installation and demo code. Here is the link: <a href="http://www.seeedstudio.com/wiki/index.php?title=RFbee_V1.1_-_Wireless_Arduino_compatible_node" rel="nofollow">http://www.seeedstudio.com/wik...
      on Oct 20,2016 10:48 AM
      Replyupvote ()
      Reply
      0
      Hi, it's possible get the battery status as Seeeduino Stalker?
      on Oct 19,2016
      Replyupvote ()
      <p>yes you can. Normally this problem is depended on your program.</p>
      on Oct 20,2016 10:47 AM
      Replyupvote ()
      Reply
      0
      An Arduino Uno has PWM capability on DIO pins 3,5,6,9,10,11. On the RFBee, only Arduino DIO pins 5,6,9 are available (PD5, PD6, PB1). Pins 5 and 6 work fine, but pin 9 does not seem to function. If I analogWrite(9, 0), it will go low. If I analogWrite(
      on Oct 19,2016
      Replyupvote ()
      <p>Yes, the power_timer1_disable() was staring me in the face and I didn't notice it. I commented it out and then the PWM worked fine. Thanks!</p>
      on Oct 20,2016 10:46 AM
      Replyupvote ()
      Reply
      0
      Is there any RX/TX pins on that module? I mean a pin that a can communicate with an Serial GPS??
      Thanks
      on Oct 19,2016
      Replyupvote ()
      <p>Hi.You can use software serial port to communicate with GPS.</p>
      on Oct 20,2016 10:45 AM
      Replyupvote ()
      Reply
      0
      I have successfully flashed one of my two (2) RFBEES, the first one has worked multipul times(using the reset method), but with the other, i have received multipul AVRDUDE errors (avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0xf
      on Oct 19,2016
      Replyupvote ()
      <p>Hi.You can download the library(not the new one) on our wiki,may it can solve your problem.</p>
      Replyupvote ()
      Reply
      0
      During the last months playing around with the RFBee I many times wished that there where two pin headers connected with GDO0 and GDO2 pins of the CC1101. Especially in modes that don't use the internal package handling of the CC1101 (synchronous/async
      on Oct 19,2016
      Replyupvote ()
      <p>Okay, thanks for your feedback , we will consider it in the next revision of this module.</p>
      on Oct 20,2016 10:44 AM
      Replyupvote ()
      Reply
      0
      When i tried to compile RFBee firmware with Arduino IDE, it give a lot of errors.. Any information on building the firmare with Arduino?
      on Oct 19,2016
      Replyupvote ()
      <p>got it to work..</p>
      on Oct 20,2016 10:43 AM
      Replyupvote ()
      Reply
        View History
        SKU 113050002
        $19.50
        10 Available
        ADD TO CART
        $19.50/1pcs+
        $17.55/10pcs+
        $16.57/20pcs+
        $15.60/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
