Mini PIR Motion Sensor Module
This is a mini passive infrared sensor that it can sense movement of people, animals, or other objects
- 10+: $5.31
This is a mini passive infrared sensor that it can sense movement of people, animals, or other objects. It features high sensitivity and instant reaction, commonly be used in burglar alarms and automatically-activated lighting systems.
The PIR Motion Sensor Series includes several products that will meet your different needs:
Product | Measuring range (theoretical value) | Features |
Grove - PIR Motion Sensor | Max Distance:3-6m(3m by default) Angle:< 120° |
Measuring distance and holding time adjustable response speed:0.3s - 25s |
Grove-Adjustable PIR Motion Sensor | Max Distance:3-6m Angle:X=110° Y=90° |
Measuring distance and holding time adjustable |
Grove - mini PIR motion sensor | Max Distance:2-5m(2m by default) Angle:X=110° Y=90° |
Sensitivity adjustable Mini-size |
PIR Motion sensor module | Max Distance:3-7m Angle:< 120° |
Sensitivity & Delay time adjustable |
Grove - Digital PIR Motion Sensor | Min Distance: 3.2m Angle:< 100° |
Mini-size Simple and intuitive |
Want to know more about how the PIR sensor works with Arduino and Raspberry pi, please click here to view the blog. If you need tutorials for operating the sensor, please click here to view the wiki.
High sensitivity
Instant reaction
Low quiescent current
Compact layout design
Specifications
Input voltage: DC 3-6V
Quiescent current: < 55uA
Detecting angle: < 100degree
Detecting distance: approx.7m/23 feet
Level output voltage: 3V/high, 0V/low
Trigger signal: High
Holding time: 20s
Operating temperature: -10-40℃
Dimensions: 28 x 13 x 13mm
Dimensions | 28mm x13mm x13mm |
Weight | G.W 4g |
Mini PIR Motion Sensor Module | 1 |
HSCODE | 9031900090 |
USHSCODE | 9027106000 |
UPC | 841454100294 |
COO | CHINA |
RoHS | 1 |
Excellent Seller and Product !!! THANKS !!! ++++++++++++
