2.2 Inch Bend Sensor - A201
  • 2.2 Inch Bend Sensor - A201
SKU 114990106
  • Introduction:
  • This force sensor is an ultra-thin, flexible printed circuit
    $25.95
    OUT OF STOCK
    This item is not available at the moment
    Get notified when it's back in stock
    $25.95/1pcs+
    $23.36/10pcs+
    $22.06/20pcs+
    Introduction:
    This force sensor is an ultra-thin, flexible printed circuit. The standard A201 force sensor is constructed of two layers of substrate (polyester) film. The high-temp model (HT201) is constructed of two layers of polyimide.
    On each layer, a conductive material (silver) is applied, followed by a layer of pressure-sensitive ink.
    Adhesive is then used to laminate the two layers of substrate together to form the force sensor.
    The active sensing area is defined by the silver circle on top of the pressure-sensitive ink. Silver extends from the sensing area to the connectors at the other end of the sensor, forming the conductive leads.
    A201 sensors are terminated with male square pins, allowing them to be easily incorporated into a circuit. The two outer pins of the connector are active and the center pin is inactive.
    Features:
    • better linearity
    • measurement of higher loads
    • stable output with respect to load area
    Specification:
    • Physical Properties:
    • Thickness: 0.008 in. (.203 mm)
    • Length:  7.75 in. (197 mm)
    •         6 in. (152 mm)
    •         4 in. (102 mm)
    •         2 in. (51mm)
    • Width: 0.55 in. (14 mm)
    • Sensing Area:  0.375 in. diameter (9.53 mm)
    • Connector: 3-pin male square pin
    Typical Performance:
    • Linearity Error: <±3%
    • Repeatability: <±2.5% of full scale
    • Hysteresis:  <4.5% of full scale
    • Drift: <5% per logarithmic time scale
    • Response Time: <5 microseconds
    • Operating Temperatures:  -40°F - 140°F(-40°C - 60°C)
    • Force Ranges:  0-1 lb (4.4 N), 0-25 lb (110 N),0-100 lb (440 N)
    • Temperature Sensitivity: Output variance up to 0.2% per degree F
    Datasheet
    For any technical support or suggestion, please kindly go to ourforum.
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    Questions and Answers
    SUBMIT
    See More
    Recommended Products
    G1&2"Water Flow Sensor
    $9.5
    ADD TO CART
    Piezo Vibration SensorPiezo Vibration Sensor
    $2.85
    ADD TO CART
    G5&4"Water Flow Sensor
    $29.5
    ADD TO CART
    G3&4"Water Flow Sensor
    $14.9
    ADD TO CART
    View History
    Best-sellers
    SUBMIT
    Invalid email address.
