seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      AlphaBot, Basic robot building kit for Arduino
      SKU 110090144
      $55.99
      5 Available
      $55.99/1pcs+
      $53.99/2pcs+
      $52.49/5pcs+
      $49.99/10pcs+
      ADD TO CART
      This kit comes with controller board UNO PLUS, AlphaBot robotic platform (line tracking, obstacle avoidance, speed measuring, IR control), and ultrasonic sensor.
      While utilizing UNO PLUS as controller board, this kit is based on the Arduino software/hardware open source platform. Combined with the modular design, it's an ideal platform to get started with Arduino robot.
      UNO PLUS Features
      UNO PLUS is a development board compatible with the Arduino UNO R3, an improved & enhanced alternative solution for Arduino UNO R3.
      UNO PLUS Vs UNO R3:
      UNO PLUSUNO R3Remarks
      Operating voltage5V/3.3V5VDual voltage level to support more shields
      ResetLateralVerticalLateral button is easier to use when connecting with shield
      Bootloader switchYesNoneThe board can be configured to run program immediately when power-up by the switch
      USB connectorMicro USBUSB Type BMicro connector is more commonly used, and shields won't be blocked anymore while connecting
      DC jackLow profileNormal heightShields won't be blocked anymore while connecting
      Power output headerYesNone
      Providing 5V/3.3V power output OR common-grounding with other boards
      3.3V power output800mA Max150mA MaxUNO PLUS features higher driving capability
      OscillatorCrystal oscillatorCeramic resonatorCrystal oscillator is suit for applications where accurate clock reference is required
      ADC channel86CFG used as ADC6 by configuration, and ADC7 from the Reserved PIN
      Connecting with prototype breadboardSupportedNot supportedSolder pads is provided for DIY interfaces to connecting with prototype breadboard
      USB driverCompatible with all main systemsDoesn't compatible with WIN7/WIN8 Express EditionDriver will never failed to install thanks to the onboard FT232
      Firmware fixingSupportedNot supportedFirmware can be fixed by using the onboard FT232, no extra programmer is needed
      AlphaBot Features
      • Raspberry Pi/Arduino interfaces, works with either one separately, or both
      • Arduino extend header, supports Arduino shields
      • Modular design, plug-and-play modules like line tracking, obstacle avoidance, speed measuring, etc. eliminating the trouble of connecting mess wires.
      • LM298P motor driver with diode protection circuit, more safety
      • LM2596 voltage regular, provides stable 5V power to the Raspberry Pi/Arduino
      • TLC1543 AD acquisition chip, allows the Pi to use analog sensors
      UNO-PLUS on board resource
      1. ATMEGA328P-AU
      2. AMS1117-3.3 : 3.3V voltage regulator
      3. NCP1117ST50T3G : 5V voltage regulator
      4. FT232RL : USB to UART convertor
      5. Arduino interface
        • compatible with standard Arduino interface with two additional analog inputs A6 (config the CFG), A7
        • solder pads provided, supports prototype breadboard
      6. ICSP interface
      7. MICRO USB connector : for uploading program OR serial port debugging
      8. Power output header : 3.3V OR 5V, voltage level configured by the onboard power configuration switch, used as power output OR common-grounding with other boards
      9. FT232 pins : for burning Bootloader into the microcontroller
      10. DC input : 7V ~ 12V
      11. Reset button
      12. Power indicator
      13. Serial port Rx/Tx indicator
      14. User LED
      15. Power configuration switch : for configuring the operating voltage
      16. Bootloader selection switch
        • turn ON : the board will reset when power-up OR other USB devices were detected connecting to the PC
        • turn OFF : the onboard program runs immediately when power-up, and the board will not reset when other USB devices were detected connecting to the PC
      Raspberry Arduino Robot AlphaBot on board resource
      1. Raspberry Pi interface: for connecting Raspberry Pi
      2. Arduino interface: for connecting Arduino
      3. Motor interface
      4. Ultrasonic module interface
      5. Servo module interface
      6. Obstacle avoidance module interface
      7. Speed measuring interface
      8. Battery holder: supports 18650 batteries
      9. Reserved power input (not soldered): for connecting other external power supply
      10. Arduino expansion header: for connecting Arduino shields
      11. UART interface: for connecting Bluetooth module, to control the robot remotely via Bluetooth
      12. SPI interface: for connecting NRF24L01 wireless module
      13. Line tracking module interface
      14. TLC1543: 10-bit AD acquisition chip, allows the Pi to use analog sensors
      15. LM298P: dual H bridge motor driver chip, up to 2A current
      16. Anti-reverse diode
      17. Power switch
      18. LM2596: 5V regulator
      19. Power indicator
      20. UART switch: turn on to enable serial communication between Raspberry Pi and Arduino
      21. IR receiver: control the robot remotely via infrared
      22. Raspberry Pi/Arduino selection: select the Raspberry Pi or Arduino to control the robot peripherals
      Infrared line tracking robot
      Infrared obstacle avoidance robot
      Ultrasonic obstacle avoidance robot
      Infrared/Bluetooth remote control robot
      Video monitoring robot
      Note: photos are FOR REFERENCE ONLY, the other boards/modules/accessories are NOT included in the price.
      AlphaBot
      UNO_PLUS
      Package ContentsProducts
      ItemDescriptionAlphaBotAlphaBot-Ar-BasicAlphaBot-Ar-BluetoothAlphaBot-Pi Acc PackAlphaBot-Pi
      RPi3 BRaspberry Pi 3 Model B
      UNO PLUSenhanced control board, Arduino compliant
      AlphaBot chassis kitmainboard, wheels, drivers, etc.
      Tracker Sensorline tracking module
      Photo Interrupter Sensorspeed measuring module (2pcs)
      Infrared Proximity Sensorobstacle avoidance module (2pcs)
      IR remote controllerremotely control the robot
      SG90servo
      Ultrasonic sensorultrasonic obstacle avoidance, distance measuring
      Accessory Shieldaccessories add-on board, Arduino compliant
      Dual-mode Bluetoothdual-mode Bluetooth module
      RPi Camera (B) Raspberry Pi camera, adjustable focus
      Micro SD Card 16GB16GB Micro SD Card, class 10
      5V 2.5A Power AdapterRPi3 B requires 2.5A or above power supply
      Note: this product requires two 18650 batteries to work, which are NOT included and should be purchased separately.
      1. AlphaBot mainboard x1
      2. Tracker Sensor x1
      3. Photo Interrupter Sensor x2
      4. Infrared Proximity Sensor x2
      5. Motor with gearbox 2PCS x1
      6. AlphaBot wheel 2PCS x1
      7. AlphaBot acrylic chassis x1
      8. Motor mounting plate 4PCS x1
      9. omni-direction wheel x1
      10. 20-slots encoder disk 2PCS x1
      11. IR remote controller x1
      12. XH2.54 4cm 4Pin 2PCS x1
      13. XH2.54 4cm 3Pin 2PCS x1
      14. XH2.54 4cm 7Pin x1
      15. AlphaBot screws x1
      Technical Details
      WeightG.W 552g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 110090144
        $55.99
        5 Available
        ADD TO CART
        $55.99/1pcs+
        $53.99/2pcs+
        $52.49/5pcs+
        $49.99/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
