seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Bus Blaster v3 acrylic case v1 (SoBv1-DP8049)
      SKU 110990075
      $3.00
      13 Available
      $3.00/1pcs+
      ADD TO CART
      A clear laser-cut acrylic case kit for the Bus Blaster v3. This case is designed to be simple, cheap, and easy to assemble. The Bus Blaster PCB is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
      This is only compatible with Bus Blaster.V3 that uses a DP8049 standard PCB template.
      DOES NOT WORK WITH CURRENT Bus Blaster V2 or V2.5!
      If you encounter any problems when using this product, here is the forum from which you can get the technical support.
      Technical Details
      Dimensions120mm x 85mm x 11mm
      WeightG.W 37g
      BatteryExclude
      Reviews
      View History
      SKU 110990075
      $3.00
      13 Available
      ADD TO CART
      $3.00/1pcs+
      • Best-sellers
      • Description
      • Technical Details
      • Reviews
      • Questions and Answers
      • View History
      SUBMIT
      Invalid email address.
