Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note: The Chelegance JNCRadio VNA 4.4GHz Vector Network Analyzer requires a USB-A to USB-C cable for charging. A cable with USB-C connectors on both ends may not be compatible with the unit’s charging system, which could explain the lack of response when connected.
  • 50kHz - 4.4GHz Wide Frequency Range:Covers a broad frequency spectrum from 50kHz to 4.4GHz with a fast sweep speed of 400 points/s. It is perfectly suited for testing MF/HF/VHF/UHF antennas, including Shortwave, Wi-Fi, Bluetooth, and GPS applications.
  • 7-Inch High-Definition Capacitive Touchscreen:Features a large 7-inch IPS LCD display with a resolution of 1024x600 and capacitive touch control. The bright screen ensures clear visibility even in outdoor environments, while the touch interface combined with 4 physical buttons offers intuitive operation.
  • Professional RF Performance & TDR Function:Provides excellent dynamic range (S21 up to 70dB, S11 up to 50dB) for precise component testing. It also supports Time Domain Reflectometry (TDR) for measuring cable length and locating break points.
  • Built-in 8GB Storage & Easy Data Export:Comes with a built-in 8GB memory card to store calibration states, .snp files, and screenshots. It functions as a virtual USB drive when connected to a PC via USB-C, allowing drag-and-drop file export without driver installation.
  • Robust Metal Shielding & Long Battery Life:Designed with a CNC metal case to effectively shield against external electromagnetic interference. Powered by two built-in 18650 batteries (6700mAh total), it supports up to 4 hours of continuous operation and USB-C charging.
Parameter
Conditions
Frequency range
50kHz ~ 4.4GHz
N/A
RF output power
-42dBm ~ -12dBm
Step size: 1dB
Connector type
N-K
N/A
RF input power
0dBm (Max)
DC < 5V
Frequency accuracy
<±1ppm
<140MHz
<±5kHz
>140MHz
S21 dynamic range
70dB
<3GHz
55dB
>3GHz
S11 dynamic range
50dB
<3GHz
40dB
>3GHz
Sweep points
1001
101-1001
Sweep time
400p/s
f > 140MHz
IF bandwidth
12.5kHz (default)
6.25k/3.12k/1k/300Hz/100Hz/30Hz
Traces
7
N/A
Markers
8
N/A
Calibration Storage
12
N/A
Storage
8GB SDCard built-in
N/A
Display
7-inch IPS LCD
resolution: 1024×600
Touch Screen
Capacitive
N/A
Power consumption
5W
N/A
Battery
Built-in 2x18650
3.6V/3350mAh×2, 4 hours with 50% screen light
Charging/Data port
USB Type-C
N/A
Charging voltage
4.7V ~ 5.5V
a 5V/2A powersource is recommended
Power output
USB 5V/1A
N/A
Dimensions
190mm x 130mm x 30mm
N/A
Shell material
Iron
N/A
Weight
1.15kg
Device
1.65kg
W/ acc and package
Operating temperature
0°C-45°C
N/A
Hardware Overview
Application
  • Antenna Matching & Tuning
  • RF Component Testing
  • Cable Verification & TDR
  • RF Circuit Design & Education
Documents
Certification
HSCODE9030409000
USHSCODE9030400000
UPC
EUHSCODE9405413910
COOCHINA
Chelegance JNCRadio VNA 7 Inch 4.4GHz Vector Network Analyzer with Capacitive Touchscreen
×1
N-J/SMA-K ADAPTER
×2
OSL KIT
×1
SMA-K/SMA-K CONNECTOR
×2
50CM RG316 CABLE
×1
USB-TYPE-C CABLE
×1
CARRYING CASE
×1
SKU 100092748
The Chelegance JNCRadio VNA 4.4GHz Vector Network Analyzer is a handheld Vector Network Analyzer covering 50kHz to 4.4GHz. Featuring a 7-inch IPS capacitive touchscreen, a robust metal casing, and 8GB internal storage, it offers professional-grade S11/S21 measurements and TDR capabilities, making it an ideal tool for testing antennas, filters, and RF components.
USD$399.00
